I am having trouble saving words to the dictionary, I cant figue it out. can anyone tell me how to get back to the tutorial
thanks joe
My girlfriend is trying it on her Eris but it's not working.Anyone using this on anything other than the DROID? Sprint Hero, for example...
If you don't change from portrait to landscape too often, you could always leave both the default keyboard and Swype enabled, and switch between them by long-press in an input field - that will bring up a dialog with an "Input method" option listed along with cut/paste, etc.
Select Input Method and choose your Android keyboard when in landscape, Swype when in portrait. Requires a couple taps, but if you don't change too often, not a big deal...
My only complaint is that when I am composing an e-mail it does not predict the contacts like before. For example I would type in someones name and it would predict the email address.
works fine on my handcent. try restating your phone maybeI'm finding that it does not trigger for several apps even if specified.
Like K-9 Mail, Facebook app, gmail app, Handsent, regular messaging.
All the ones you really want it for. I though it was cool but if I can't use it where needed, it annoying.
It' very hit and miss.
says it only works on WVGA phones. so hi-res screens only for now. i'm sure they will be coming out with a version that will support everything else. Also there is a program that is just like this called slideIT that is coming very soon to android.tried it couldnt get it to work on the g1 =(
looks like it would be awesome tho
