Root Synergy ROM Problems
M
Member 628401
Guest
I successfully flashed Synergy and partitioned my SD card. But now the problem is whenever i navigate away from the home screen and i click the back or home button to go back to the home screen it always pops up with the HTC screen like when you turn it on, not the HTC EVO 4G splashscreen just the HTC screen right before it loads the home screen. How do i fix this to where it doesn't show it everytime i click the back or home button?
Happens on 3.0 sense roms and gingerbread roms and gingerbread stock unrooted EVOs. Also, even on the 3VO.
No real fix yet.
i don't think it happens on every sense 3.0 rom. i was on kinged kingdom and now mik3d and nothing like that happend. i would get it once in a blue moon on synergy-kingdom rom i think it was the previous nightly 7/17. 7/22 nightly did not have that issue for me.
I don't see this often either. Last time was back on MikG 1.2 or 1.4. I just wiped and reflashed, problem gone.
Not saying it happens all the time but I've read on other forums that it happens and the common factor is gingerbread(stock EVO and 3VO) and/or sense 3.0 roms. So far, I haven't seen a fix.
I always thought it was actual Sense reloading, regardless of ROM - but i switched to LP right after i flashed MikG so i don't have that issue. It was annoying though...
Ok, have you tried to go into Spare Parts and scroll about halfway down the screen to where it says "Activity process management, and choose normal?
Sounds like it is set to aggressive, which will close Sense itself everytime you leave it to run an app.
also you can try the v6 supercharger script that's being talked about in another thread here. it will lock sense in memory so it won't get killed.
there's also something you can do manually to the build.prop that was posted in the xda thread, but it will take forever to find. it's something something LAUNCHER=0 or something like that. it should keep the launcher in memory as well. I'll see if I can find it
eta. you add the line ro.HOME_APP_ADJ=0 to the build.prop but the v6 script does that already. try running the script it's working really well for me
