markzombie82
Hey guys i found this file on my phone and automatically started googleing.
http://forum.xda-developers.com/showthread.php?t=1430145
It seems there is a way to remove it i haven't tried it yet cause i wanted to see if anyone else has first.
You just take away the Wright permission for the file. And remove the contents to the SD card for safe keeping.
If i have this file i know some of you do to if you've been throttled it will contain files.
I've read some scary threads about bootloops. So MAKE A BACKUP if you want to test and play with it.
I'm not currently throttled but have been in the past and have noticed large downloads that aren't playstore get throttled bad so if you have the same symptoms. You most likely have the same files screwing with you.
Wait there is this
http://rootzwiki.com/topic/6645-data-throttle/
I'm running g60 cm7. r09
Wait there is this
