Stay put I have two lines with metro unlimited all with international on both and insurance on my s3 my bill is $130 a month with tmobile same plan runs me about $170
the devices cost more
Added a screenshot. $180 with unlimited on 4 lines.
I've noticed that T-mobile is cheaper than Metro for unlimited. Or am I mistaken?
I'm paying $205 per month for 4 lines. All unlimited. 3 at $50 and one at $55.
Should I jump over to T-mo?
Forgot to add picture.![]()
Gotta add in the device payment per month as well.
After the phones are paid off, then yes that will be your total payment for the month.
which is what i was talking about, he was talking about 4 lines and tahts all there is to it, still need to buy phones which means monthly payments or a upfront buy which they tend to be more as gsm devices are more valuable.
I think someone said before that only the first 2 lines have unlimited data, and data has to be purchased for any more lines. Call t-mobile to be sure.
I also read somewhere that their unlimited it's throttled at 5gb's. And that would suck cause my daughter always gets close to that.
Thanks for all your inputs.
If you have the 70 dollar prepaid plan, or tack on the extra 20 dollar unlimited to her line, then it will not be throttled, (unless she manages to pull 1TB of data in a month(and if that's the case, you should check out her phone & internet usage)). The 30 dollar prepaid plan is the one that gets throttled at 5GB. The standard plan and the 50 dollar prepaid plan gets throttled at 500MB, and the standard plan + $10 add on or the 60 dollar prepaid plan gets throttled at 2.5GB.
Actually I believe they cut it down to Edge speeds, so roughly 200kbs.even then, the "throttle" cuts you off from 4g speeds, tmobiles 3g speeds still beat out sprint/verizon/metro.
its not like you get cut off just slowed down, and for anyone using 5gigs a month.. perhaps they should slow down.
Tmobile throttle is anywhere from 50kbps - 119kbps thats what I've seen
I'll bet you can take a stab in the dark as to What bodily orifice they can do What With their Regulatory Programs fee and their 6-28% taxes.
:smokingsomb:
Bruce in Ocala, FL
:smokingsomb:
Bruce in Ocala, FL
