hi everyone,
I am %100 sure that the battery issue is caused by the camera button. (case half-presses the camera button and that's why the case seems to be the source of the problem)
Here's my experiment:
POSSIBLE CAUSES (before experiment):
a) cause is not the case.. something else..
b) case touches the screen, screen is too sensitive
c) case presses the overly sensitive camera button
EXPERIMENT:
a) I charged the phone fully last yesterday evening. When I left the phone as it is on the table, phone slept perfectly, battery worked normally. (it was at about %96 after 7 hours)
Then I put the phone in its case and left it on my bedside. When I woke up (after 7 hours) it was at %50 !
Conclusion: Reason IS the case.
b) I thought it was possible for the case to activate touchscreen sensor and keep the phone awake, so I just did this:
* plugged for charging
* put your finger(s) on the screen
* unplug and when screen is awake, press lock button to make it sleep
* wait like 5 secs, then open "Spare Parts" and look at statistics.
Conclusion: the phone slept perfectly (without the case, fingers on the screen) so touchscreen is definitely not the problem.
c) tested this:
* plugged for charging (without case)
* press "camera button" fully
* unplug, press lock button to make it sleep and wait 5 secs
* open "Spare Parts" and observe statistics.
Conclusion: Phone did NOT sleep at all! The problem is definitely the "camera button"!
It doesn't matter if it's fully pressed or half-pressed (tested both).
We need an URGENT firmware update for this!
Does anyone know any developers at Samsung??
