amazin1988
If your using the tethering that comes with the ROM you have to go to change device profile and put it on LG optimus s and it will work
I just dl'd Clockworkmod's tether app and all I can say is hell yea! its fast, I had it working in less than 5 minutes! Im not at all a guru at this type of thing, still in noob school,lol. I rec it for everyone wanting to tether, the only down side , but not really is its a trial app, good for 13 days. ill buy it after the trials up fo sure!
QUESTION: id the other tether "tether v3 app real easy to get going? Please advise..thx!
I've been using the one that is in the roms.. just WiFi tether... it's. worked great till yesterdat. now I get a message from metro PCs saying "WiFi teetering is not supported" but only on some sites... Th and you tube work fine .. I'm rooted and everything... any ideas???
Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; LG-MS910 Build/GINGERBREAD) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1
To those that have gotten "blocked" can you guys estimate how much data you have used?
i sometimes use over 1gb in a single day!!
Google firefox user agent
First, you have to be on the 70$ plan..... Then use the firefox "user agent switched" (ad-on) and set it to Iphone.... now everything is working for me!! at lightning speed!!!![]()
This did not work, a google chrome fix please? Anyone else?
