Nope CDMA/LTE onlylg spirit is gsm??
Now its to the point if you want to tether, you have to pay, simple as that.
That's not true.
There are work arounds if you will root and use a Tether app.
Bruce in Ocala, Fl
Then if you have a defective phone, and need to have it serviced you have to use a flash count remover, lose data, and spend all that time backing up data/ recovering data, all to tether? I'll pass.
What I meant by this is if you want to tether legally then you are just going to have to pay. What happens if you do root, and then you use the workaround, and get caught? I'm sure it says somewhere in the TOS that they can just cancel you without notice if you tether without having the plan. Why couldn't they just keep it the same way Metro had it. I'll stick with my Motion, and squeeze every last drop out of it until 2015.![]()
Your arguments are both non-sensical And contradictory. First the non-sensical one. If you take your phone in for service unrooted, they're going to wipe it for you anyway. You'd still have to do the backups you have a problem with here.
I have not rooted a phone yet. Haven't really needed to (though I came very close to needing to with the Motion). Remember that you're not really "fully" rooting with the LG locked bootloaders. It's easy peasy to do, easy peasy to undo. And basically impossible to wreck your phone doing and impossible to detect once unrooted. Even *I* would do this simple of a root to tether.
In the other thread on this you mention a main reason for this question is so that your father can tether movies Oftenly. And now for that pesky little contradiction thang. There's no way NOW on Metro for you to tether Movies Oftenly WITHOUT Either paying for it Or violating your TOS. (You won't tether many movies on the new plans legally with only 250 Meg tethering.) Which from what you've said, you and/or your Dad are Already doing with Metro. If you are even using a User Agent Switcher and the onboard app, and not paying up you're just as in the wrong as you'd be doing it on T-Mo. The only difference between Metro and T-Mo is What they do When they catch you. T-Mo puts the screen up, Metro doesn't worry about it til you bust the hard limits.
So far as getting caught goes, if you are tethering the way someone would do it and not be gaming the system, your amount of data actually used tethering would blend right in with the rest of your usage. You Wouldn't get caught.
Bruce in Ocala, Fl
I wonder if it has something to do with the fact that T-Mobile now allows tethering on all their postpaid plans?
Hmm, that's weird. I have a prepaid plan, so I know I don't have the tethering option. But looking at their postpaid plans, it explicitly states the unlimited has 500mb of tethering, but the limited plans don't explicitly say it like the unlimited does, but there's also no way to add it. I'll have to investigate more when I have get a chance.This can't be true because once i switch user agent back to desktop i get redirected to tmobiles page something about buying their tether plan blah blah..
I am also on prepaid plan. Weird part is i think i still got that 500 mb free. When I first brought my phone home i used it to download the necessary files to root and get a custom rom on. It then redirected me to the page i mentioned but by then it was too late for them. All is needed is to change user agent on the custim rom.![]()
Ok, I'm on a Spirit so I can't try this but this seems to me a fairly popular option for T-Mo, using a VPN. You can do that either rooted or not. It seems to work best for everyone.
How to tether using T-mobile unlimited 4G without getting blocked | ferGeeks - Guides fer Geeks
That thread suggest using Hide My Ass VPN but it's a pay one. (I can vouch for HMA simple Proxy as I use that to bypass our local newpapers subscriber only noose.)
A search for FREE VPNs points to CyberGhost as being a good one.
So here's one option someone with a GSM phone can try if the usual User Agent Switcher method doesn't work.
Bruce in Ocala, Fl
Yeah, prepaid doesn't include it natively, only postpaid does. However you can add it to any prepaid package if you feel like it.
They wont let you add it to the unlimited plan, I tried.
