bouchigo
Android Expert
I finally got around to porting BWC to v4.5.595 because of the uncertainty with v4.5.596 (OTA).
It's been working good so far with no issues that I have noticed. If you guys catch anything that I missed, please let me know so I can get on it and correct it.
You guys know the usual disclaimers about "you" being responsible for your own phone, etc.
MUST READ before installing:
1. Make sure you are deodexed before installing, otherwise you will be in "force close heaven"
2. Check to see if your Market has been updated to v2.3.6. Go to Menu/Settings/Applications/Manage applications, select the "All" tab and scroll to the market. Select "Market", and if it shows you are on v2.3.6, uninstall the update before proceeding to install the theme, otherwise your market will force close and will only be fixed by flashing your backup.
You might want to freeze/rename your MarketUpdater.apk so your Market won't update after uninstalling the update, or so it won't update your newly installed themed Market later on when a Market update is released, unless you want it to update
5/18/11
Theme Download Link v4.5.595(all current mods included):
http://www.mediafire.com/?jrp1t91pzunlpf6
MD5 Checksum: c592dc3020c3147ee109691b8e878489
Deodexer for v4.5.595
http://www.mediafire.com/?xs9lwe67aez7sv5
Whenever you have issues like boot loopingthis, or FC, etc., apply the deodexer through CWR, reboot, wait 3-5 minutes to boot into OS, then apply the theme......this applies for any theme.
Get back into CWR by doing battery pulls until you boot into CWR.
Disable Slide Unlock when Pattern Unlock enabled
http://www.mediafire.com/?qbjrjlo90vif4jh
Mod to remove/add clock from status bar:
Remove Clock
http://www.mediafire.com/?q08hgt6cisunft3
Add clock
http://www.mediafire.com/?x061jn83i8jao81
Market (by me):
Has the latest market v2.3.6, themed Black Market.
Settings Menu and Stock Dialer (by me):
Have been inverted to black, no longer the light colored background.
AppWidgetPicker:
Included to clean-up/group your widgets menu.
TV/CRT Animation and 270 degree rotation:
This theme has the mod
Data Throttle:
Removed data throttle
Dialer One (modded to match BWC):
It comes with the most recent v1.3.3.
Note:
When you first install BWC Dialer One it will not match the BWC theme, it will be a gray color. To make it match the BWC theme, do the following:
When in the app, go to Menu>Settings>General settings>Application theme and select the "Black" option, and that will do it
Dock Icons:
If you want the dock icons I am using, search "Tallmin icons" on Google and you will find them very easily.
BWC folder installed on SD Card has:
- "Addon" folder that contains addons such as, BWC Dialer One, Modded Pandora.
- Dock backgrounds for Replacement Home apps and some wallpapers.
** Expect a long boot up after applying (3-5 mins) **
Follow these links for more info. and screenshots:
http://androidforums.com/droid-x-all-things-root/328505-theme-black-white-chrome-gb-v4-5-591-a.html
[Theme] Black, White, and Chrome for Gingerbread 2.3.3.4.5.588 Latest Leak
[Theme] Black, White, Chrome for Leaked Gingerbread 2.3.3
[Theme] Black, White, and Chrome for ApeX 1.4.0
[Theme] Black, White, and Chrome for Liberty 1.5
[Theme] Black, White, and Chrome for Liberty 1.0
Black, White, and Chrome for GummyJAR 2.5
Black, White, and Chrome for Fission 2.4.2
collection of ported themes for fission 2.5.7
5/18/11
Remove Clock
Add clock
Market (by me):
AppWidgetPicker:
Data Throttle:
Note:
Dock Icons:
