inFECT
1. (Blue) Version: Dark Sense 2.1
*** FOR A CHANGELOG CLICK HERE *** FOR A DOWNLOAD LINK CLICK HERE ***
(25.08.2010) - DarkSense 2.1 Final
100% Compatible with Galaxo 1.6.3.4
Fixed the Notification Text Bug.
Compatible with the optimized libdvm by jakax for Galaxo 1.6.3.4
Added the Super Circle Battery
Added ADW 1.1.3 System Version as Standard Launcher with "Sense" Theme
Added Wysie Contacts.apk 2.8 with Dark Sense Theme - Compiled from drakaz
Added new images in the settings for Wifi Connect
Changed Lock Buttons again
Tweaked some images which did not fit properly.
Thanks for testing: Obihoernchen, Casper Span, sgx100, maurinet, Marjun and all others.
Special thanks to: Aglar and Drakaz
DOWNLOAD HERE DARK SENSE 2.1
How to install: (Use at your own risk!)
Dark Sense 2.1 is compatible with Galaxo 1.6.3.4 - It is not tested on other ROMs or Galaxo versions.
- Copy the theme to your root directory on the internal SDCard.
- Perform a nanodroid backup.
- Boot in Recovery Mode and fix the permissions.
- Use the "apply any zip" option and choose the Theme.
- Finished!
Sidenote: If you dont like the ADW Sense Theme, go to Android Codex and download the latest flashable Donut System Version.
How to remove:
Download: Back2Galaxo.zip and proceed with the steps above. Done!
2. (Blue) Version: Dark Sense 2.0
The Dark Sense Theme is compatible with Galaxo 1.6.3.2 / 1.6.3.3.
Choose a theme version:
DarkSense2.0_ADW-Sense.zip (HTC Hero Sense Style ADW Launcher)
DarkSense2.0_ADW-Standard.zip (Standard ADW Launcher 0.8.2)
DarkSense2.0_Advanced-Sense.zip (Advanced Launcher with HTC Hero Sense Style)
DarkSense2.0_Advanced-Standard.zip (Advanced Launcher with DarkSense Style)
- Finished!
3. (Grey) Version: Dark Sense 1.6
DarkSense1.6_ADW.zip (Standard ADW Launcher 0.9.0)
DarkSense1.6_Advanced.zip (Advanced Launcher with DarkSense 1.6 Style)
- Finished!
How to remove:
Download: http://box23.org/pub/7500/custom_roms/galaxo/themes/inFECT/Back2Galaxo.zip
Sidenote: If you upgraded from 1.6.3.2 to 1.6.3.3 via patch, the theme wont probably work.
You have to make a full install of either Galaxo 1.6.3.2 or 1.6.3.3
For older releases go to www.androidcodex.com/files/
