Root [THEME] ICS for OA 2.3.20
With the free live wallpaper
Sounds like work but alright
All I did was find and replace four instances of call to busybox in the updater script and then the theme flashed. Spz0 pointed me in the direction of the script. Before that I just manually pushed framework and systemUI. YMMV.
I made a killer theme I call grey scale but I can't post it cause I used some paid icons I bought.
What y'all think?
if you like it I can give you the theme without the icons. I'll post the link to the icons and u can buy them. (.99 cents) and I added a cool lwp
I love this! How can I get this?
And how do i go about doing this
I love the ROM, it runs great. I spent some time with UOT and also decompiled framework-res and SystemUI to activate the CRT off and also added some kickazz window transition animations as well as making a few changes to the UI, just to make it more mine.
Can someone give us a step by step tutorial on how to use kitchen for the admire...I keep breaking my head to get this thing right but I don't have alot of time on my hands due to work...how do I use script ? Can I use it on Linux ?
Thanks
:confused:
Thanks
:confused:
Well it's not complicated. Just upload your framework-res and systemui under file upload, uncheck theme chooser preview, and just make sure when editing you have mdpi selected
Damn i love how looks now...settings (love it) , and theme (love it) keep up the good work kagebeast
Thanks man. I'm still trying to edit some things. Like the text in the notification bar. I'm about to update the link again since i changed the battery and also the progress bar.
Do you mean the OA 2.3 text? When you decompile framework-res.apk therein lies the answer. :)
No i mean the text of notifications
Could someone tell me how to package the free apps and my theme so out can be flashed. There are a few people that like it lol.:(
so i realized that the problem with the UOT Kitchen always giving the black text in hte notification bar has nothing to with the actual theme. anything that is handled by the framework will be themed out but the notification from the actual text comes from the app itself so in order to make the text white one would have to decompile the apk's and actually go in and change that. that is so complicated. it would be easier to change the the notification color to a a lighter color like grey. id do it myself right now but the UOT kitchen is being a b**** and i cant accessed it plus i dont have access to the already baked theme so id have to start from scratch. im thinking maybe ill try and make my own theme so see how is goes :D
i guess i could just make a notification drop down bar theme, make things super easier
Kage:
what color code for blue did you use in UOT kitchen. im using 00A3F8 and it seems like its fairly close to the one you have. the network icons (3G/1x) also dont really seem to match ICS so i would say change it to the G16 Cianbread ones cause those look more like ICS. and the battery icon to have the actually percent numbers, it saves having to download an app from the store for that. i am suggesting these changes but im also making these minor changes myself to get it more to my feel.
Enigma:
what program is that where i can change the script? notepad++?
Kage:
Enigma:
Well there are different status bar icons when it comes to ics. If you look at the icons for the lg motion it's similar to mines and plus cianbread is a completely different theme so i'll leave that as is but yeah i will try and add the numbers to the battery. Although i hate seeing how low my battery is lol
lol everyone has a different preference, i get ya. ill just do that myself:thumbup: i hate seeing that too but its better than wasting a bit of storage space using an app dont ya think? btw what code for the blue did you use for future purposes?
edit: i figured out it is notepad++ but i read im supposed to save the edited file as All Files, is that correct?
I'm not sure about the color since i was pretty random about it
thats fine i just wanted to keep evrything matching in color but thats fine. ill stay with the default blue they give, it seems pretty close to it :) i hope that i cooked the theme right though
EDIT: well i tried to make a them but got than error through both of the ones i made, oh well i guess i ll just leave the theming to those that can do it.
can you fix the status bar it looks bad make it more ics looking ive tried but i cant see my text at all its all black
