check out the latest work to ldk-ick zvclots of changes made, still more to come.. not too sure about statusbar yet but tell me what you think
Looks good to me. I like the status bar. Great work.
I have a problem with changing the LCD density. The bottom app drawer is too small so the right portion is blank. I have the homeless kernel installed with a 200 dpi. I didn't search the theed to see if there was a fix sorry. And I installed just the theme not the ROM/mod
Hmm..rebooted after changing the density right(just checkin)
Strange for sure![]()
can do a theme for the stock rom????
Haha those screenshots are for ld_lg zvc(stock basically) ldk_ick theme, but I think it can be flashed on any rom zvc
The one on here is intended (built around) gse, but the zvc version im workin on is for ld lg zvcTheme - Flashable theme for GSE ZVB mmm i can install on my stock rom ZVB or only for GSE
that image does not look like the density id restored to 240... lol do adb pull of build.prop and see if your method had actually changed it.. if not than manually change the build.prop, push it to device and reboot.. that should solve your prob
sadly i forgot to add the corrected lcd density to this theme lol i put it on arctic but not this... but im getting new version together now along with zvc version so i will be SURE to update the lcd density back to 240!!
oo haha well you know that with an irregular lcd density youll have market issuesI know its not on 240 lol. I dont want it on 240. I have it at 200 but you can see that its falling short of extending all the way through. I might try arctic though. Sorry I'm not getting mad at you or anyone else, its just that I suck at explaining things lol.
BTW you made an awesome ROM/Theme. I love it
yep fixed that with lcd modder pro![]()
If I were you, I would put the LCD density back to normal and not fiddle with it again. It may cause adverse affects to your screen that are permanent. This is coming from experience.
what's the reason for changing it? I think the density is perfect. I'm not trying to call anyone out or anything I would just like to know what your reason is for changing it? bigger? Smaller?
