Root [THEME] MS910 LD-ICSK v2.4 {ZVD} [ICS Hybrid]
Love your work, going to donate soon. Quick question though, I am using UOT Kitchen and i need to know the update binary scripting type. Does anyone know? I know its edify scripting but is it emmc or something else?
The default setting in UOT kitchen should be fine. Just upload the correct files, submit it, download it, and flash it. ;)
And I agree that this theme work is amazing lol...I know what kind of time and patients it takes to do this lol...I will definitely be donating when I have extra money :D
hii off topic but i install this rom nd the home kernal but it since like my phone crashes alot i wld like to noe if anyone knows why wld tht be??
Great work yet again.
Is it possible to change the battery icon to show the percentage like LD-ICS v 1.2?
Thanks
check out the latest work to ldk-ick zvc :D lots of changes made, still more to come.. not too sure about statusbar yet but tell me what you think :D
i love it! is that a power control widget? i love the power control widget but i cant seem to find it in the current version of this rom...or did you just add it??
that themed power widget should be in all versions... im uploading the first zvc version now :D check the op in 5-10 minutes
wtf? i long press on my home screen and select "widgets" and there isnt any "power control"...is it somewhere else or called something else? if not i dont have it lol
or maybe its because im using adw launcher??
ooo that could be... kinda like how sense widgets dont work without its launcher.. do you have lghome as well or no?
Yeah that's it...I have both launchers installed but adw is my default launcher...dammit...adw ex is just to smooth to get rid of lol. I could always download a power widget off the market...but seeing how awesome yours is I won't be satisfied until I have it! Lmao
OP Updated!!!! ZVC version now available!!!
Love your work.
Question: anyway to have Zvc with the look of Zvb? I like the near stock ICS look of the Zvb theme. I like the uniform look of it. Is that possible? Also, could the settings text be the same ICS blue instead of the LG green?
Thanks!
I flashed the zvc LDK ICK rom and everything went fine until it boot up. I keep getting force close on "com.android.settings" and I can't get past the lock screen. i reflashed it and the same thing occurred. Perhaps a bad download? idk...:confused:
Edit : I just flashed the theme and it works fine, the problem was I deleted data/factory reset.. The status bar looks great.
haha send me the one you end up downloading and i can theme it for ya :D
Love your work.
Thanks!
yeah soon :D i actually want to make 2 versions... hybrid/stock ics 'look' lol lot of work to do :D
