Root [THEME] MS910 LD-ICSK v2.4 {ZVD} [ICS Hybrid]
Great work yet again.
Is it possible to change the battery icon to show the percentage like LD-ICS v 1.2?
Thanks
You can do it with UOT Kitchen in less than 5 minutes. ;)
Can i also use rom toolbox to change the battery icon?
When opening the icon changer I get a "Please Read. Changing your icon modifies framework in your devise."... "If you are running a Theme Chooser Theme then you must have the 'System' theme selected or this might not work."
I'm not familiar with what this means.
Yes you can. "If you are running a Theme Chooser Theme then you must have the 'System' theme selected or this might not work." is regarding the Tmobile theme chooser in CM7. Just disregard all that and hit okay :D
Awesome! Thank you for all your help so far.
new lockscreen coming soon inspired by P-Bot :D
not sure how to lose the glow yet lol but it adds a touch of class i think :D
Hi what's wrong with the link keep getting error 404
i removed old 1.6 so people wouldn't download it :D new one should be up & running!!
1.6
-MT's power menu Mod
-New lockscreen inspired by p-bot
-few more things themed but still a WIP!!!
Screen shots available for zvc 1.6
The rom version is built on ldlg. Which is basically a slimmer stocker gse2 lol same kernel.. so its up to you
Sent from my LG-MS910 using Tapatalk
Anyway I can have just the lock screen? I have Kane's ICK theme. I hate using widget locker and magic locker. They both kinda suck.
you need the android.policy file and RES_cappuccino.apk, from this rom lol and that will give you the lockscreen but it will also alter your statusbar header and widgets
Is that lock screen in the b and c version or just the C? Im running OG GSE
its only on c, to add it on b i would have to remove the power menu mod... im going to ask mt if he can do what he did for zvb then i can make it work
