Root [THEME] MS910 LD-ICSK v2.4 {ZVD} [ICS Hybrid]
Lockscreen on zvb
Mr peanuts beat me to it, everything looks good, luvin the new lockscreen. Although I think it'll look better with out the metro PCs thing on there lol
haha im still learning this asi go.. im suprised i got those letters blinking correctly lol im not really sure how to get rid of the metro
First problem I found... when I hold down the power button my phone reboots.instead of that options window popping up.
damn good catch bro I forgot to check that out,but ur right it does reboot ,it dosen't give u an option to recovery
ok :D had a feeling that would happen.. lol so i cant do it untill we get stock lockscreen with reboot option for zvb, untill then you can flash back or use an alt app for rebooting and powering off
THX BRO!!!! ill keep it,ill just use rom manager for recovery
The only problem i found with the theme/rom is adding widgets. The modded home has no problems adding widgets, it is only when I use launchers such as "360 launcher" or "TSF launcher" even widget locker. I get a pop up saying "com.android.settings has an issue", so I need to force close every time.
It does the whole reboot thing when you press power on the ZVC version too. Also has anyone successfully made a theme from UOT Kitchen for the esteem yet? Ive tried every option and always get an error. I just want to add text to my header and cant seem to do it. Ive done it with my Optimus but not the esteem.
i used uot kitchen for font color.. changed it all except header.. :( not sure why
Lol they are both far from stock.. i just havent decided which mods to keep and which not.. i jus need some time to think all this stuff out
Sent from my LG-MS910 using Tapatalk
