LDrifta
No Stranger 2 Danger
what did you flash the theme on? what rom?i updated back to zvc and running v1.4 ICS Hybrid and its running great.
well the zvc version is only a theme right now, so what rom did you have prior to flashing the theme? or did you flash a zvb version?i flash this LDK-ICK v1.4 with Plague-Extreme_2.2_signed kernel, and battery life is good also.
haha send me the one you end up downloading and i can theme it for ya![]()
I'm getting "Please Insert a SIM Card" after flashing, any suggestions? thanks
After a reboot, emergency calls stays active for maybe 10 seconds before going away and whenever i power off the display it reads please insert sim, No sim card and emergency calls only at the top right
I got "please insert sim card" also.
Whats the difference between zvc mod and zvc themed
k check if ur lte card is inserted the right way open thu back of ur phone and check ur lte card if u c do not remove on the bck of it turn it around try it
lol that was my fault... didn't edit eri.xml so with the aosp lockscreen it told you to insert sim but everything will work fine!! i updated the 1.5 with framework from gse II so now the themes will work on both gse and ld-lgI got "please insert sim card" also.
sadly not yet lol... i took a crack at it before but gave up... will try again tho lol untill then i can throw the old themed one back on..?Is there a theme for the Google search update yet?
zvc MOD is the whole LD-LG 1.5 rom with ick theme applied!!Whats the difference between zvc mod and zvc themed
this one i have no explaination for... lol bad dl??Just put the.new 1.5 every time I reboot the phone my ringtone rings with out stoping ?
Sent from my LG-MS910 using Tapatalk
haha i actually fixed that on 1.5 zvc version lol but still have work to do... thanksLove the look of LDK-ICK v1.4, great job!! Is there any way to make the in-call dialer match the out-of-call dialer? It's just that the latter is beautiful and the in-call one is somewhat funky/hard to read.
