Pro isn't necessary, but I think it allows for batch backups and restores, saving time. You can backup and restore with the free version but only 1 at a time
Also, tip for those who like to keep their messages (like me) I haven't figured out if TiBu can b/r SMS, but in all the time I've used it I haven't seen that option. Go SMS pro allows you to backup your texts to restore to another ROM.
email app is missing. Gmail one is there but the one called 'email' is not there. Can someone confirm this?
It wovrked for me on a comp, but gave a bad download on phone. Try your computer if you haven't already, in the meantime I'll start uploading my copy to my drop box in case it still doesn't wobork
k on my way home now and as I can see thr list gets longer lol
I will update the kernel, try the bluetooth fix and fix some ui issues I and others have noticed.. I removed email app but can put it back if anyone needs/wants it, plus I will fix issues listed earlier
everything is good just wondering if u could make the time blue it will look real nice if u could thx!!!!!
I don't think he could, at least not without changing all the text blue as it shares the same font as the whole phone.
I was able to do it with my theme, its in framework_res ... /res/layout/status_bar_expanded.xml
you can also have it where just the time is blue and not the ticker.
When I try to install this, I get...
--Installing: /emmc/LD-ICS v1.zip
Finding update package...
opening update package...
installing update...
installation aborted.
Can you help?
