Root [THEME] MS910 LD-ICSK v2.4 {ZVD} [ICS Hybrid]
not sure if it has been brought to your attention but the font color in certain menus need to be changed. for example if you go to the music app then press the menu button and then press more you will see that you cant read anything because the background is black and the font is black
Download from computer
Connect phone to computer with mass storage mode enabled
Move .zip to sd card (internal or external, don't think it matters where)
Boot into recovery and install as the instructions say
EDIT: wait for update before you do this, looks to be soon
Looks like i'll have to because I did all of those instructions to the letter and it won't work, surprisingly GSE works every time though
I was trying to figure out how to do that, perhaps now with this bit of info I can now lol
now im thinking its in res_cappuccino... I can't remember and im not near my computer atm
is there anyway I could use wat u did to make it blue on his theme
all you would have to do is extract the xml file from mine and place it in the other apk
I'll look tomorrow to verify which file it is.
if all else fails you can use the UOT Kitchen, its super easy. The hex code I used is 33b5e5
thank you for letting me know, but sadly that will be with the next update lol i will most likely work on that tonight just not sure if ill finish because there's more i want to do with the xml's while i have them decompiled :D but so far i got the browser, bookmarks and email issues taken care of :D
let me know if you figure out the txt problem, same thing is happening with the ICK theme
k :D ill let you know, haven't got there yet... almost done with everything else tho.. just doing ui touch ups and will release an update :D need testers
What's it look like?
click below.
0
I really like the feel and the new icons. however, the internet does not work, wifi also goes off and on randomly. I tried installing fb and it crashed
Uploading now :D made some tiny changes and fixes... i haven't even tested yet im flashing it as i type this.. will post link here before initial release...
LD-ICS test 1
please tell me what i missed, what dont work and what i should add :D thank you
crap i already found some things lol
-didn't take out alarm clock (because the other clock app has an alarm clock)
-fix menu background for black txt lol (but hopefully by changing text to blue it will fix that)
-ICS keyboard FAIL lol
LD-ICS test 1
k so this link u posted is the new update
not the official update, because there a few more issues to be ironed out, that link is just for those who would like to test and see if there anything else i missed...
k cool imma test it out right now ,but do i need to wipe anything?????
