if mt doesn't post one soom im going to look into thatEverything been running great since yesterday. Great job Idrifta,apprieciate all the hard work you've been putting in. Anyway to get the reboot and reboot into recovery option on the power menu
thank you!
thank you!
how did you get the zvb one? my dropbox links are down for 3 days lol time to pick a new hosting siteJust flashed the ZVB ROM and gotta say, pretty smooth. Getting some lag as I type this but everything else is running as smooth as butter. Thanks!
how did you get the zvb one? my dropbox links are down for 3 days lol time to pick a new hosting site![]()
i have no idea what you mean by that....Hi I love test8 but the notification box a little short
I just wanted to say I've been having a random issue with the ZVB ROM V1.4. As of a week now it started to not show the lock screen when the power button is pressed. It lights up the bottom buttons but the screen is black. The only way i can fix it is if i pull the battery and restart. It was pointed out that it might be the phone isn't mounting the SD card but that isn't the problem. I don't know what if could be?
of ld-lg or the ick theme? lol this is the thread for theme.. but uhhhmmmm i updated all the roms if maybe you would like to try the latest version?
can anyone check and see on theyre test 8?Not sure if its me, I am running ldriftas test 8, with root, I cant seem to click on preferences in super-user. I have downgraded the app, upgraded it. I then went back to other builds the preferences work fine. I think I am in the right place cause this is The theme forum, I also posted it in Root. I also sent him a PM "shrugs"can anyone check and see on theyre test 8?
Mine works Josh in v8:thumbup:
Sent from my LG-MS910 using Tapatalk 2 Beta-4
that's wired I'm use t8 and I'm able to get to preference my super use is 3.0.7 su binary is 3.0.3
earlier i downgraded to see if it was my root method, but seems to work on my stock zvd, and 3 other backups I have, but not zvd test 8.... heres the screenshot of the FC, like i said all functions of SU work just not the preferences, I can live without it. ill also post a screenshot of my root check
r u running ld lg vs 1.8 rom with t8 if not try it like that that's how I'm running it
Gotta ask a noob question, Ive been gone off this forum for a alittle... and just got a very odd call... so noob question away, " what is LD LG, and where do I get it" i just used the search box and typed it in and nothing
its on this thread go to Thu first page ld lg vs 1.8 rom its the official rom for zvd with speed kernel
