Root [THEME] MS910 LD-ICSK v2.4 {ZVD} [ICS Hybrid]
I take it there's Bluetooth issues with this theme too?
Like it was already said its the settings.apk. Spc had the same problem and all he did was change out 15 icons. Something about changing out the icons breaks Bluetooth. Just either A. Like stated flash the Bluetooth fix that's in the Gingerfusion theme or swap out the settings.apk yourself in the system/app folder with the stock settings.apk which I also posted in the Gingerfusion theme.
Its broken in KaneOfMars theme too....
Yea, I know LoL... I was just letting him know. I tried posting a couple of times before letting him know the fix but must have missed them due to all of the feedback/problems/useless talking there HaHa. It's alright, not a big deal.
lol yeah honestly i there so many things in my head that i want to fix on this so i have like scatter brain lol need to start writing some of these things down... but i will take care of the issue as promised guys lol sorry for delays..
my BT works on Kane theme with GSE, and i never had never use the settings.apk file. Every esttem is different in their own special way. Darn LG, lol
I love the theme ... can you give me just the theme ... for install it to CWM ... I have the stock rom .
ok i think i have a mis-understanding of the whole recovery.img... from what it sounds like, your saying that the recovery has a base rom, so if i wipe everything and then reboot it will boot into a rom? lol i always thought it would just boot loop since there was no system installed..
so what is the base of this recovery? stock rooted or gse?
o wait... i think i know what you mean now lol
correct me if im wrong, but you have the stock rom and you just want a theme you can flash on top of it via cwm?
Running a AnTuTu for S&G's first...what kind of feedback would you like I? Love the look:D
mail
Clean...don't use bluetooth at this point(One other thing has been taking up much of my time ;)
Looks good!! :)
mail
Looks good!! :)
Just noticed...the time is a wee bit off???:confused::confused:
ok im confused... lol time for what is off? and what was that picture, and did you test bluetooth? lol sorry i just couldn't fully understand what you meant...
Pick was a benchmark score..not too shabby. Bluetooth still a no go for me:thumbdown:
pJfO9RnC
My clock is 5 hrs off from real time.
Sent from my LD-ICS v1.2 using Tapatalk
:image:
Your time should be set automatically. There may be a way to change it yourself, as we had to do sometimes when flashing roms on the ascend, but I don't see any.
When I just reflashed GSE a few days ago my time was off by 7 hours. But after I rebooted and flashed the latest Gingerfusion my time was corrected.
Was looking for a place to correct it...but yeah..reboot and fixed...hime installed(hate the swype) Lol
Bluetooth working for anyone or? Or do I need to ^^^
My bluetooth has always worked guess i'm one of the lucky ones
The Wipe Data?Factory Reset option ONLY deletes the User Data added to the phone not including apps that we add to System/App manually because Wiping Data doesn't touch that folder because if it did then it could make the phone unstable.
The Bluetooth fix does work well for me it did i flashed last after i did the rom. works good so far
GO BEARS
