TattooedDroid
The menus are all blacked out. Black on black. Which is lame because this is awesome! Holding me over till cm9
+1.. I can't break 1.8..
Another issue I noticed is battery drain.... quit massive lol hopefully can fix it
kk lol, you did make sure to grab the modules too right?
dl'ing via pc or phone? if from phone, dl it from a pc n copy to your sdcard n try it.
Yeah that's the next fix. Wanted to edit font color but I'm gonna need help with that.. probly jest change the backgroung grey for now..The menus are all blacked out. Black on black. Which is lame because this is awesome! Holding me over till cm9![]()
as soon as i go into my gallery and select a pic it goes into automatic Crop mode ???... when you hit the menu button then click on gallery, it'll take you into another gallery selection. then it happens
needs Fixing
Are you sure you had a good download? Check the file size. I don't have that issue at all.
not many can including me lol. Its simple, not all phones are created equal.![]()
you need to flash the 2.2 kernel then lollol no my phone can handle 2.2ghz but i cant goes pass 2.0ghz because setcpu not letting me but i fixed it i flash the kernel over
try pulling the app from your device "adb pull data/app/*******.apk"Little situation when I install ics+ it just force closes when I unlock it and also it acts real weird
maybe thats why the phone comes stock with flash player? ill put it back in and see with next test... what type of video are you trying to play? because i know camera recordings from device play fine in gallery and video player appCan anybody use stock HTML5 for flash video I can't watch videos or movies help. Please e
then push it to the rom zip file, and remove the LG Home.apk
then reflash your new rom![]()
made a few minor updates... nothing special tho, i looked into the bluetooth thing and ill fix it but i need a confirmed working copy of settings apk, not sure which rom has it...
as for battery life... im not sure lol the tweaks are already in build.prop, only other thing would be the kernel.. because LD-LG has great battery life so for now just do normal adjustments (brightness, sync, data etc...)
hoping i fixed menu background but it is giving me some serious issues... and i still cant seem to locate a decent boot sound...
So pull it and then , open the zip and put it in there and then delete lg home apk or push it through adb
the updates i did are not on 1.1, i will upload tonite after a few more tweaks.. it gets better each time1. What's the boot sound of the nexus? If it's something generic (as in, doesn't say the carrier name, Verizon?) you could try that.
2. Are these updates uploaded?
3. Could you change the topic title to reflect the current version, so it's easier to tell if you have a current version?
