Fabolous
Superuser
This is a port of Manup456's NexTheme for the Motorola Droid X. It is meant to be run on deodexed Froyo 2.2
If you are running Froyo, but not deodexed, consult these threads:
[HOW-TO] Manually deodex your phone. - Droid X Releases - AllDroid Public Board - [HOW-TO] Manually deodex your phone. - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
DISCLAIMER: I am not responsible for anything that may go wrong in this process - Though with the SBF file now, it is almost impossible to brick a Droid X.
Includes
-Themed Framework and some apps
-Custom NexTheme Font (removable)
-Themed MotoTorch and Ringer widgets
Downloads
NexTheme: Fabolous_NexTheme_Froyo_DX.zip
Default Fonts: Stock_Fonts_Froyo_DX.zip
Battery % in notification bar: Battery_Percentage_Froyo_DX.zip
Installation
Requirements: Rooted, Deodexed Froyo, Koush's Droid X Bootstrapper
1. Download file(s) and place the .zip files on the root of your sd card
2. Reboot into Clockwork recovery
3. Install .zip from sdcard, choose zip from sdcard
4. Install NexTheme (and customizations if you wish).
Note: If installing default font or battery %, install NexTheme first, then apply patches.
5. Enjoy your new theme!
Outdated - For Android 2.1 Only
Screenshots
For even more screenshots, check out the original NexTheme thread here:
[THEME] NexTHEME-v2.0r2-Enom_1.9.2/CM_5.0.7.1 Back In the Kitchen! =) - Nexus Nation Forum
Includes
Downloads
Installation
Changelog
V2.1: Fixed the horizontal progress bars (the weird behavior before a download, etc.)
V2: Fixed the pull down buttons so now you can read the white text. Themed MotoTorch and Ringer Control Widgets now included! Optional wallpapers can be found here:
nexpapers.zip
Instructions
1. Download 'MetaMorph' from the market. Run it once and grant it root permissions.
2. Download the following file:
NexTheme_V2-1.zip
3. Extract the file. Make a folder on your sdcard called nextheme. Extract the contents of the 'framework' and 'apps' folder into sdcard/nextheme. Extract the contents of the 'metamorph' folder into sdcard/AndroidThemes
4. We will first need to push framework-res.apk and services.jar to the system. Open up your terminal emulator or adb (preferably) and type:
after this reboot, you should notice a different status bar, but the clock and time will still be black.
open up terminal emulator (or adb) again and this time we'll push services.jar
the following reboot will take between 3-5 minutes!
Now the clock and time, etc. will be white.
5. Now, fire up MetaMorph and choose unzip/extract new theme, select nextheme, and let it do it's thing extracting. Once it's done extracting, you can apply all the themes (for the apps), or apply only the ones you want.
6. Using the 'Files' app that comes with the Droid X, you can navigate to sdcard/nextheme and install the widgets if you'd like. You can see what they look like in the screenshots section.
7. Enjoy your new theme
nexpapers.zip
Instructions
NexTheme_V2-1.zip
Code:
su
mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
cp /sdcard/nextheme/framework-res.apk /system/framework/
reboot
Code:
su
cp /sdcard/nextheme/services.jar /system/framework/
reboot
Screenshots
