Root [THEME][WIP] p-bOtMOD ICS MINT(UPDATED 7/12/12!)
p-bOt
Android Expert
ICS MINT THEME!
FOR ZVD!!
FIRST OFF...I AM NOT RESPONSIBLE FOR ANYTHING BAD THAT HAPPENS AS A RESULT...BLAH BLAH BLAH...YOU KNOW.
This theme is ICS with a little twist :D like ICS and HTC Sense got it on without protection :D I will be updating more system apps and fixing anything that is wrong as I go along! THANKS FOR CHOOSING p-bOtMOD!!! COME AGAIN!!
INCLUDES
-ICS Wallpapers
-ICS Sound FX
-ICS Window Animations
-ICS Swipe to Clear
-MT's Power Menu (with all needed files for screenshot)
WHAT'S THEMED(for now)
-framework & system ui
-analog clock widget
-download provider
-power control
-settings
-boot animation
-pattern lock
-CRT Shut Off
-other little things here and there :D
DOWNLOAD LINKS
p-bOtMOD ICS MINT v. 2.1.0
p-bOtMOD ICS MINT EDIT TEXT CHANGER!!!
INSTALLATION INSTRUCTIONS
-Copy Zip file to sd card
-Boot to recovery
-Make Backup
-Wipe Data
-Flash Theme
-Reboot
SCREEN SHOTS
NOTE
IF YOU WANT A MORE AWESOME EXPERIENCE CHECK OUT "HOLO LAUNCHER" IN THE PLAYSTORE!!! ITS AWESOME!!!
SPECIAL THANKS TO ldrifta FOR ANSWERING A MILLION QUESTIONS LOL :D AND TO V SUPERUSER V FOR SOME AWESOME AND VERY INFORMATIVE TUTORIALS!! :D
CHANGE LOG
v.2.1.0
-Themed LG-Contacts.apk
-Themed Phone.apk
-Awesome new text fields
-other shit that i forgot about but its awesome
-fixed framework-res.apk to work with ICS Gallery from PlayStore (check it out!!)
-more stuff that i forgot about lol
v.2.0.0
-fixed spinner issue in drop down bar when downloading
-changed USB icon
-themed mms.apk
-replaced all icons! :D
-fixed some things in framework-res.apk
-themed CameraApp.apk (still working on it)
-added ShinySide's smooth scroll mod
-replaced stock calculator with ICS calculator
-couple of other things I forgot.
-oh! and i kanged a couple of ldriftas system apks from ICK v2 to hold you off for a couple days while i finish the last few system apks lol.
v.1.0.1
-changed "on/off" buttons back to check marks (saddly)
-changed boot animation (let me know what you think...i can change it back or to something else!)
I would resize the on/off buttons so they don't overlap the text
The screen shot is just to show the size of the buttons, your volume screenshot shows the overlapping :)
Yeah dude I know lol...I had them like that before but it just looked so bad ass to have whole thing there that I was gonna try and move the text around it first. But if I can't ill defiately make them smaller again lol :)
Could you link the "swipe to clear" xml?
dude...swype to clear was the biggest pain in my ass lol. its not just one xml file lol. its a bunch of files from "framework.jar" and "SystemUI" when decompiled. specifically:
in SystemUI.apk
res/anim/
res/layout/status_bar_latest_event.xml
res/values/public.xml
smali/com/android/systemui/statusbar/LatestItemContainer$1.smali
smali/com/android/systemui/statusbar/LatestItemContainer.smali
smali/com/android/systemui/statusbar/StatusBarService$7.smali (or depends on your numbering, could be $8 or larger)
smali/com/android/systemui/statusbar/StatusBarService.smali
in framework.jar:
smali/com/android/internal/statusbar/IStatusBarService$Stub$Proxy.smali
smali/com/android/internal/statusbar/IStatusBarService$Stub.smali
smali/com/android/internal/statusbar/IStatusBarService.smali
ldrifta linked me to this [HOWTO]Implement Swipe to Remove Notification - xda-developers when i asked him about it. so this is your best bet lol. but if you just want the edited files i would decompile the framework.jar and system ui in my theme. you are going to need AVA box or some other baksmali editor to decompile it tho :D
I knew there was others but i was assuming there were files in the framework apk, as that was the only one of concern. I can just pull those. I'm trying to implement it without disturbing my theme, basically pasting only what i need to, to my theme.
Thanks for the info.
nice! :D well if you just put the framework.jar in there it wont hurt anything. and you could just decompile the system ui and take what you need and put them in your system ui i dont mind ;) just as long as i get a huge thanks in your OP lol ;) just hit the thanks button bro. gotta build my street cred lol ;)
That's what i plan doing. ;)
Want to get noticed and build cred really fast? Do something no one has seen. Or something no one has covered.
Vsuperuserv is a great example. He came in and right off the bat he made 3 guides that hadn't been touched on yet. Just from that he proved he was reliable.
Not saying you aren't but that's the fastest way to stand out and not blend in with everyone else. "thanks" on posts are helpful but it's all about what YOU can offer the esteem users. That's the key ;)
So I pulled the res/ani and the res/values/status bar latest. Then pulled the resources and classes. Pushed those to my systemUI. I already had the framework.jar that was modified for the swipe to clear.
Pushed the files and got it working. Surprised I got it working that easy. None the less thanks for the info on the files. ;)
Hmmm...that's weird...are you sure you got all the files?? It might be the framework.jar. try just pulling mine and pushing it to yours
Yeah I tried that. Still nothing. IDK. Its not a big deal, honestly I don't like it but I just wanted to see if I could do it. hahaha. The mind of an OCD person. lol
Okay so it was installed after all.
You have to swipe it just right for it to clear out. Or the screen will move up or down or it wont clear. lol. Id rather just hit the clear all button. Least I got it working and I can ease my OCD shakes. haha
Haha that was actually my second guess lol. if something was wrong it would force close lol :)
why is it that when i load this theme on my wife's phone it like get's half of the theme and still has some things from her last theme she was useing? she has number 2 1.8.3 plague kernel...
