Root Themed Android Market
FragDroidX
Android Expert
Don't like the way the stock 2.3.2 market looks? Change it to one of the selections at this link......
[APP]::20-02-11::NEW Themed Market 2.3.2:: Honeycomb versions & 2 whites added::: - xda-developers
They are supposed to work on any ROM except for stock. There is pretty much one there that should work for any theme you are running. I have used them on Liberty 1.5, Apex 1.4, and DS v4.2 with no problems.
All the time I spent learning how to theme the market; had I known about this I would have just passed on it and used these.....lol........then again I probably would have spent that time anyway :D
so, i downloaded the black/neon red market .zip to my computer, copied it onto my sd card, then did an install via bootstrap, but the market is still stock, and i cant find anything in my app folder. whats my next step?
btw i am running apex 1.4.1
Thanks very much for the heads up. Neon Honeycomb was perfect for what I'm doing. Installed thru Root Explorer since I read some people with X's were having trouble with the flashing thru clockwork.
Now just need a nice swype keyboard that looks the same and I think I will be done for today :)
This worked for me also running Apex, I just extracted the vending.apk from the zip on my computer and put it to a directory on my sdcard then did the rest in root explorer
http://forum.xda-developers.com/showpost.php?p=11509747&postcount=59
Installing via bootstrap did not work for me either, I had to extract the vending.apk file, move it and change the permissions with Root Explorer.
It looks good with the rest of my blue/black theme.
Ok how to I install via Root Explorer and what permission does it need?
Thanks!
Ahhh, nice find and thanks for sharing!
Will these hold if the Market updates or will we have to install a newer version of these?
Thanks!
Unzip the file and grab the vending.apk file from the system/app folder, then place it on your SDcard, then use root explorer to move it into the system/app folder on your phone. Then long press on the apk file and select "permissions" then change them to: User: Read, Write; Group: Read; and Others: Read. Then just restart your phone.
My market is still 2.3.2. I don't think 2.3.3 is out yet.
Perhaps someone is confusing this with the 2.3.3 OTA update coming out for Nexus S?
Thanks man.
I tried what you said with Fission 2.6.1 using just the stock theme but now the market is force closing constantly. :\
Looks like its nandroid time.
I go to settings/applications/manage applications/ tap all go to market and i have version 2.3.3
Thanks man.
Before you do that go to the menu button, settings, applications, manage applications, all applications tab , find market and clear the cache , that has helped me in the past.
I tried to do that, but the market was not even showing up under there. Weird. Guess that's what I get for trying to install the new market. Guess I will stick with the old one for now until Team Defuse updates Fission.
Thanks though.
I lost the black market two days ago while others lost it a few days prior to me. This would suggest that my phone updated two days ago and my market is currently 2.3.2
