J6Remy
Blue me is on my dropbox and don't know how many of them.
Hey C, you can add a blueme to bitly and it will count the downloads on that theme.
Hey C, you can add a blueme to bitly and it will count the downloads on that theme.![]()
Let me know when you tried again if it works or not and also if you have any problems with any of the others if you do it might be you and if not I will see what I can do for you.
I went and tried another and it worked then i went back and applied the inverted and it worked.
Thanks for all your help.
How about a purple & black theme? This would look really nice on my phone. like a voilet type purple, not the pinkish purple![]()
Almost like the pink it theme or the blue me theme, I don't know about the wallpapers though but I'm sure there's something to go with it. Purplish black swirl or something
On prevail but I use my optimus s time to time using Xparent purple tapatalk
Do you make these at the hot kitchen? I can not figure it out
I still have to make a purple and black, but is she running the 3.8 now? Also I will start to update the themes when I can, being springtime is very busy for me. I might also ask gus if I can update his too? It may be a while but I will get to them! Let me know which ones to start on first!
It just changes your settings text and look to the way it was before and the swipe in the dropdown doesn't work either, the way it was before. Now if want to flash a theme just MAKE A BACKUP FIRST and then flash a theme and if want back just restore your backup! Will make a back to stock as soon as I can unless Gus makes one first!
Like always, themes not made for this release will break fixes/changes and restore data/app's at your own risk. If you do either of these and have any problems don't come here posting about it lol.
...and undoes any fixes blood made to the system ui and/or framework...
By flashing the theme, your changing those 2 .apks back p the ones from the previous build
Didn't even think of that, should I delete the post then?
Well, basically its use at your own risk. They may work, but you will lose the benefits of any enhancements blood may have made.
I think blood summed it up: if you use one and something breaks, don't come complaining in the ctmod thread that its broken![]()
You can update my themes whenever you want C, you have my permission to do it,
It'll be my pleasure that you do the update for these themes.![]()
Will do more when I can and will make a new thread fo 3.80 stuff.I love the prevail comradery.![]()
