It's finally out of beta! Release Candidate 1 of UD3 is out NOW:
Droid 3.0.0 - (Release Canidate) - The Ultimate Droid - Forums
Go get it while the gettin's good!
Changelog since beta:
- Updated build to 2.3.2 (sms bug fixed)
- MASSIVE performance improvements since 3.0.0 beta (faster, much more memory available)
- Made a lot of changes to the new theming engine
- Added fix for cdma phone signal issue
- Began Work on New UDLauncher3 (dustinmj/anderweb/blackdroid)
* Fastest 3D launcher on the planet
* Long press for customizable shortcuts
* Customizable number of shortcuts,
* Customizable launcher style
* Customizable launcher background
* Scrollable widget support
* Cleaned up code, made a few changes to launcher workspace
* (Full screen mode, Resizable widgets, Customizable number of screen, hide icon labels, and double tap to show previews still to come,)
- Added new scrollable galaxy s notification widget (customizable from ud settings - cvpcs)
- New Overhauled Music App w/ 5 widgets(Josh Stone)
- Phone and Messaging Lockscreen options are now "Phone and Custom App"
- Phone and Custom App now works with rotary lockscreen as well as the tabs lockscreen (Sven Dawitz/Blackdroid)
- Sound On ->> Vibrate On ->> Sound Off - Toggle On Lockscreen
- Rotary lockscreen + Phone and Custom app = new rotary lockscreen layout (hint
ull down)
- You now get rotary answer widget when rotary lockscreen enabled
- Removed Carrier From Status Bar and made clear button bigger (scroll to bottom of list to access clear button)
- Added Maket Apps Installer (by kmobs)
- Even more work done on UD Settings Overhaul (not fully complete)
- Porting UD Theme over to new theming system (not fully complete)
Things STILL not working:
- UD Settings can only be accessed by long press search or selection from an open launcher
- Camera
- Accelerometer
ull down)- You now get rotary answer widget when rotary lockscreen enabled
- Camera
- Accelerometer
I like the UD ROMs, but the dev has some of the strangest business and/or behavioral practices I've ever witnessed. Whatever... For now I'll just stick with LGB. I do take enough pics for this release to be a non-option for me.
