Compared volume side by side with 2.1 DX. Identical.
+1 mine is MUCH louder!Mine is without a doubt louder.
Mine isn't louder. I measured pre and post install with the decibel meter I use in my home theatre, it was identical. I will check again after a factory reset.
Thanks for confirming. Like I said "it seemed louder" until put to a real test. Placebo effect. I really hope the factory reset helps.
are you guys speaking on the speaker playing from the back?
Perhaps not as good a test as many may think. While it is an objective measurement, there are many factors that could affect the levels measured and without knowing more about the process and equipment used this could be an accurate comparison or of minimal relevance.Mine isn't louder. I measured pre and post install with the decibel meter I use in my home theatre, it was identical. I will check again after a factory reset.
