PeeLoWanKenobi
what am I doing wrong? It comes up with an error message when I try to open it after DLing. I tried using astro manager too.
Edit: Nevermind. I got it to work
I knew you'd have it sooner or laterWith Froyo, how do I get access to my SD card? All I get now is the verizon mobile popup when I plug in my phone.
How come there is an update but it is not available via the market or appbrain? I understand you can update it via the .apk but if there is an update out there shoudn't it be available for all?
Is it possible the udpate isn't verified for the Incredible?
so where do you check to see what version you are running ? 72 or 90 or whatever? derp.
I was able to install the .apk by using my phones stock browser and navigating to the link provided earlier. Download the file, which should show the status in the notification bar, and once complete just install by clicking on the downloaded file.
Ok. Figured it out. Was running the 72 version prior to the update. I put the .apk on my SD card...then opened it using Astro File Manager. It asked if I wanted to update, clicked yes and it installed the new version fine.
So lesson learned for this .apk...cannot install from the computer using ADB/SDK.
P.s. the browser scrolling is now very quick and some of the flash sites I had checked before seem to load even a little bit faster now with the update.
Changing the plugins to on demand only helped me slightly...but after I updated to the 10.1.92.8 scrolling is at least as fast as it was with 2.1
version: settings->Applications->manage applications->click on adobe flash...How do we find out what version we have?
Where do we change the 'on demand' plugin?
thank you.
I tried the on demand option but didn't like it yeah ur webpages will load faster but at the cost of making all the flash content have arrows and no pics. The whole idea with flash is to see the preview pic to see if u want to click it. I keep it at always on. Just get the new flash version it works faster.
I downloaded it to my PC, connected the phone to the PC and copied it to the SD Card. Disconnected the cable, went to Astro but cannot find the file using Astro. I can only see directories, not a single file on the SDCARD. How do I see it with Astro?
The best way to suf the webernet!!99% of flash content is ads.
I guess I love seeing those empty ad boxes. Reminds me of Firefox with the AdBlock+ and NoScript extensions running.
I have DropBox, so I downloaded the .apk from the computer to DropBox, then installed it from my phones DropBox. Pretty slick.
. Been emailing files, plugging in to transfer them. PITA. Just read your post and was like !^$#^&$ DUH!!!!
