Root Too late for MIUI Gingerbread?
Did you add the adreno drivers like you normally would on any other rom?
i flashed the zip Hroark made
Also to anyone who gets a bootloop, it will most likely be as a result of two things. 1-no sdext on sdcard, or 2-you need to perform a factory reset or at least a wipe of sdext, the script does not format the ext. Shinny new ROM + old ext data = very boring movie about an Android and a barber pole :D
Can anyone else confirm a force close for me? Go to settings under Personal then select Location & Security/Use wireless networks then select it. I've been getting a force close when it's activated and it stops when it turn it off. It gives the error as problem with Google and Gapps. I just sent Blovadova a logcat but wanted to see if anyone else is getting the same force close.n Thx
With all the action happening in this thread.... I'm almost tempted to test out this ROM and give it a whirl to see what happens. Now if only I can find that blasted download link.
@biker I can confirm the FC on nbl. Gapps crashes as soon as you turn it on, and when I left it on and did a reboot, framework fc'd after boot and the launcher froze (everything else was ok, notification bar, etc.) I had to hit search, search for settings and turn off nbl. After that my launcher was fine again, and the fc's stopped
Great thanks! Time to explode my prevail.....
You're going to love this ROM.:D Just don't try to set Location & Security/Use wireless networks it will force close more than likely. It will stay checked after you select it but you will continue to get force closes every now and again, especially after a reboot. If you deselect it, the force close error will cease. It's really no biggie since most everything still works without it being checked. ;)
Thank you LV. It is not just an isolated event then. That's good to know. I've already sent him a logcat with the error in it. :D
Also, it will stay selected and the phone will run but you will get the force close when you reboot if the box is still checked.
Thank you very much for the input guys, I appreciate it. Gotta get off of here for a while. Holla at you guys later this evening. Time to get some studying done, mid-terms on Monday. OUCH!
Ok, I rebooted and no FC...
Hmmmm, have you changed anything in the system? (this is with fresh install for me, system as is in the zip)
You use beautiful widgets correct? Does it show you accurate location with GPS off and nbl on?
Even with it on i still could not get it to geolocate.
The only way I was able to get it to show my location was by selecting 'force GPS for location' AND opening maps to get location (if I just refreshed bw it would flash the GPS icon for a second and then say 'location does not exist' and location remained unknown)
Yup fresh install for me as well, (got locked out by my locker, forgot to disable both options before installing the last theme...) :p
Perhaps my question was unclear, with ONLY network based location on, are you able to locate using wireless networks? (FC or no FC)
Does nbl work on your phone?
This may have already been answered but just curious why when I apply a theme it does not change the toggles to the way they are in the theme screenshots? Has anyone else ran into this issue?
That's not true, there are 2 versions in the replies on that thread, and if you read close enough they say that 11.0.1.152 is the one that works with interaction with apps/games and such, I read the whole thread before posting this... Btw, it works well here on my MIUI... :p
You are correct, i re-read it, it was worded tricky, or i need some sleep... But either way...
Okay next issue I saw mentioned before, On certain menus the text and background color are the same making the words unreadable, any recommendations on how to fix this?
I don't have that problem but I am also using a theme so that could be the reason I'm not having that issue
Sent from my SPH-M820 using Tapatalk 2 Beta-6
