Root Too late for MIUI Gingerbread?
Does anyone else have iffy battery? I feel like my battery drains fast and I have a extended battery also I think airplane mode doesn't work like it should instead of saving battery In places with no to poor signal I feel like it doesn'tsave the battery and in fact make it worse. Also can others tell me how they're battery is and if they have done anything special?
It helps running CPU master pro with screen off profile set. If I lay off it lasts all day
But with all this cool shit who wants to do that????
:cool::rolleyes:
What's up peeps!!! I am relaying a msg from B-love....He apologizes for not dropping in but has informed me he is experiencing technical difficuties...I do know updates are in the works BUT.....don't know the eta....
On a different note.....
Anyone please help!!
Ok I have had Ubuntu installed on a dual boot...however when I run Ubuntu and try to connect wireless in WILL NOT EFFIN CONNECT!!! WTH??? It has connected one time and that one, when connected for EFFIN 5min, it knocked my phone off of wireless????????????????????????????????????? Can ANYONE please comment WTH is going on here?
Thanks
O
Man, i wish i could help ya but i know very little about Ubuntu.:o
Windows is a different story. I'll PM a buddy of mine with the link to your post and see if he can help you. ;)
Thanks
O
What kind of lock or passcode? wep, etc?
Anyone else not seeing any signal bars? (they are there but i always have 'no bars') it's either how the signal strength is interpreted, or the images themselves being wrong (all the same?) Same in every theme i tried... I am using the phone now, so clearly i have signal... (i sure miss the dbm display option on cm7... And worse the option is there in this ROM, but broken, as if to mock me :D:D:banghead: )
Anyone else not seeing any signal bars? (they are there but i always have 'no bars') it's either how the signal strength is interpreted, or the images themselves being wrong (all the same?) Same in every theme i tried... I am using the phone now, so clearly i have signal... (i sure miss the dbm display option on cm7... And worse the option is there in this ROM, but broken, as if to mock me :D:D:banghead:)
No signal bars or 3g. Same as you ... doesn't work with any of the themes.:afraid:
I believe it is the 11.10 version.....Thanks for the link gonna give it a look :driver:
To be honest, I really know nothing about Ubuntu, I've had a few failed attempts to get it right, and still trying. I don't find the Ubuntu threads helpful as I thought they would be. Well for my issues anyway.
I want to use the Wubi. installation, but the damn thing hangs up in the copying files portion of the load.. I still have the dual booting option, but no Ubuntu.. :(
I agree with you all the way around on that J6!!! Threads = HUH? lol.....I can get it to boot BUT....no connection....get right to the finish line and get a flat!!! WTH!:mad:
My bad J6. I thought that you had fixed it and up and running.
I know someone else that I know for sure has got it up and running. Lemme send them PM. Again bro, thx for getting back so quick. :)
i used to use virtualbox but decided to dual-boot. now i rarely go back to win7.
for the wifi problem you can try this
sudo ifconfig wlan0 down
sudo rmmod -f iwlagn
sudo modprobe iwlagn 11n_disable=1
sudo ifconfig wlan0 up
it'll reset on reboot if it doesn't work. if it does work you can search those commands and find out how to make it permanent.
It's no problem bro, I'm always down to help when I can.
BUT! If anyone that has some time on there hands and wanted lend helping hand for a few PM's to get Ubuntu (by Wubi) on my PC I would be their best friend..Ohh the things I can do with my hands.. lol Like make pizza or cat-head biscuits..LMAO
Just for clarification, "cat-head biscuits" DO NOT contain cat heads...
the virtual box eats up my RAM, that was my first encounter of the third kind..
WHAT! Cat head biscuits! Man .... now I'm hungry. Heh, I made a homemade banana bread tonight and it almost gone. The wife and I put a hurtin' on that sucker. MM MM MM . :eating:
Hahahah.....I have been trying to change those bars for awhile now and am at the same point as you guys....:banghead: :hmmmm2:.............:ahhhhh:
Ya thought it was just the theme
Had to completely hard reset my router recently changes wep key but resolved connectivity
