cjreyes666
Has any one gotten a look on the touch recovery for the LG Black and see if it can be ported to our devices? Thanks.
I just ran a build for itWould you have a build for the Ignite as well?![]()
just swap the .img out in the installer you used to install it (not RM) and rename accordingly.probably not the smartest question...but do you just flash this and it overwrites the existing cwm?
It's been a long time since installing clockwork mod. I try to avoid RM so no worries. What what you recommend as the easiest method/installer to use?just swap the .img out in the installer you used to install it (not RM) and rename accordingly.![]()
Is CWM still installed to mmcblk0p4?
yeah, if u wanna wait a second u can use the one im uploading if ur using windows. Doing the linux/mac script now
edit:
All i did was edit playful's aio and removed the root options, upgraded the recovery.img. Will work on windows/mac/linux (run script accordingly). I am not responsible for what people do to their phones.
Goo.im Downloads - Downloading LGMarquee_AIO.zip
Works great, had to flash manually since goo.im wasn't loading.
how did you did it mine stays on waiting on device
Monster, I keep getting this error when running the script on windows:
/data/local/tmp/sh: permission denied
Should I flash to stock and try again?
I'm currently running CTMod 3.6.8
Files/$adb shell /data/local/tmp/sh -c "mount -orw,remount /dev/block/data /data"
:CWMTOUCHRECOVERY
CLS
echo Rooting the LG Ignite
echo Tool Built by mtmichaelson
echo Exploit Built by the Revolutionary Team
echo CWM Touch Built by PlayfulGod
echo.
echo.
Echo Root and CWM Touch
pause
Files\adb kill-server
Files\adb wait-for-device
echo Device found
echo Pushing Touch Recovery
Files\adb push Files\cwmtouchrecovery.img /data/local/tmp/cwmtouchrecovery.img
Files\adb shell /data/local/tmp/sh -c "mount -orw,remount /dev/block/data /data"
echo Installing CWM Touch Recovery
Files\adb shell /data/local/tmp/sh -c "dd if=/dev/block/mmcblk0p4 of=/sdcard/mmcblk0p4.backup bs=4096"
Files\adb shell /data/local/tmp/sh -c "dd if=/data/local/tmp/cwmtouchrecovery.img of=/dev/block/mmcblk0p4 bs=4096"
Files\adb shell "rm /data/local/tmp/* 2>/dev/null"
echo Finished Installing Recovery!!!
Files\adb reboot
pause
GOTO MENU
remove thisLooks like this is missing?
Here's what I came up with for the .bat file. Haven't tried it yet thoCode:Files/$adb shell /data/local/tmp/sh -c "mount -orw,remount /dev/block/data /data"
Code::CWMTOUCHRECOVERY CLS echo Rooting the LG Ignite echo Tool Built by mtmichaelson echo Exploit Built by the Revolutionary Team echo CWM Touch Built by PlayfulGod echo. echo. Echo Root and CWM Touch pause Files\adb kill-server Files\adb wait-for-device echo Device found echo Pushing Touch Recovery Files\adb push Files\cwmtouchrecovery.img /data/local/tmp/cwmtouchrecovery.img Files\adb shell /data/local/tmp/sh -c "mount -orw,remount /dev/block/data /data" echo Installing CWM Touch Recovery Files\adb shell /data/local/tmp/sh -c "dd if=/dev/block/mmcblk0p4 of=/sdcard/mmcblk0p4.backup bs=4096" Files\adb shell /data/local/tmp/sh -c "dd if=/data/local/tmp/cwmtouchrecovery.img of=/dev/block/mmcblk0p4 bs=4096" Files\adb shell "rm /data/local/tmp/* 2>/dev/null" echo Finished Installing Recovery!!! Files\adb reboot pause GOTO MENU
Yea I adb pushed n ran the dd cmd manually myselfCan I just push it with adb?
remove thisCode:/data/local/tmp/sh -c
