johnlgalt
Antidisestablishmentarian
/me is not an op....
Apparently I am an OP, didn't notice lol....
from Koush:
MMS videos are fixed.
##program fixed
Fixes for Launcher2. Toggleable 4/5 column Launcher.
... and probably a few other bits and pieces..![]()
I've also been checking out UD10. Performance is on-par with CM, maybe a little faster. There are minor differences in the two, and not to diss CM or brag up BD, but UD10 did not give me any troubles. I did however have a few problems with CM. Only thing I can think of is that since BD didn't use ALL of the CM files, something must work better. That's an educated guess from my BB Storm days, where I actually used to mix and match my own hybrids.
I understand both sides of the argument..although the flamewar really got out of hand. But in the end I will run whatever ROM runs best, and I really want/need apps2sd(200+ apps on my Droid).
Yankee, if you'd like to read up on UD10, and get support for it, UD has it's own site now, ultimatedroid.com. So far they are very active in answering questions and posting solutions. There is also no bad talk of CM in there. They seem to acknowledge, though not directly, that UD10 is based on CM.
I'm not a BD fanboy..just putting out info. I'm actually waiting for a 100% Droid version of CM, or any other ROM with working apps2sd. I'm hoping some of the other devs explore the apps2sd option..
