Hi guys,
I was partitioning my SD card to install the new EVOlved ROM using the following instructions. I got to step #6 and realized that I don't know how to get the ROM back onto the SDCard from recovery, lol.
How to Flash (If you don't want to partition sd skip to step 5)
1. Back up sd card on computer and make sure you have Amon-RA
2. Go Into recovery and go into Partition sdcard
3. Then Partition SD
4. Then stay in the partition sdcard menu and go to SD:ext2 to ext3. Do that 2-3 times
5. Wipe data/factory/reset, cache, and dalvik cache. or use VR Superwipe or something like that
6. Put rom on sdcard
7. Flash The Rom Like Normal
8. Then boot into heaven
Can anybody help me out?
Thanks in advance!
Thanks in advance!
