Root [UnBrick Guide]LG LEON LTE - MetroPCS (LGMS345) KDZ Firmware
Okay, I'm having difficulties with my LG Leon. I'm on metroPCS with version ms34510f ? Would this guide still be applicable? I tried rooting it and now it's stuck on the metro screen and won't turn on or even go into a bootloop. I also can't get into recovery OR download mode. Help anyone?
I just bricked the one I got two days ago I am downloading the kdz file but is taking for ever.i hope this works I didn't do back up because I was too busy trying to root the phone.dumb mistake I hope this works.
I have tried every method to root the 10F but same, phone soft bricks, you need to reflash the kdz files.
I have a LG Leon MetroPCS with 5.1.1 LGMS345 ms34510e etc....
I was trying to root it and I used a method someone linked on another furom that was actually for the 5.0 update, however even though it said it was successful once I tried to restart the phone it just get stuck on the metro start up screen indefinitely. I want to try this method of fixing it but now its now showing up properly on the computer. It says MTP driver failed to install...device failed to start. I know the drivers are installed because it was working prior to trying to root it. I'm no longer interested in rooting and I want to at least salvage my phone. What do you recommend?
PS: I could never get Kingroot to work though everyone one online says it works perfectly for this phone
The method listed on the first page of this thread will bring your phone out of looping/soft brick . when it reboots do a system update from the phone
I found a way to unbrick the Leon LTE for MetroPCS.
Standard disclaimer: This is for MetroPCS ONLY and is the MS34510D version. This guide is for people who have bricked their phone due to messing about with important files/partitions on their LG LEON LTE and found that it won't boot up and gets stuck in a boot loop. The method used in this guide should only be used as a last resort. Don't hold me responsible if this method doesn't restore your phone or makes it worse. THERE IS NO WAY TO DOWNGRADE BACK TO ver MS34510B after using this method.
Installed
LG United Mobile Driver 3.14.1
LG Flash tool 2014 (build 03/07/2014)
After flash tool installation
1. Remove the battery and put it back in.
2. Hold the Volume Up button (ONLY) while connecting to USB Cable
3. The Volume up button needs to be held until it reaches download mode
4. Open device manager and changed the LGE Mobile USB Serial port to COM 20
5. Open the Flash Tool
6. Select Type: 3GQCT
7. PhoneMode: EMERGENCY
8. KDZ : MS34510D_00.KDZ
9. Click on Normal Flash
10. Click on Clear update registry
11. Country: different country
12. Language: English
13. Click okay and wait for the LG Mobile Support tool to recognize the device. It takes a minute or two but the tool will recognize it. The software starts the extraction and re-boots at %100. You can remove USB cable, your device will boot normally, and the device is no longer stuck in a boot loop.
Files needed:
LG Drivers: https://mega.nz/#!oQV3yS6Y!D2JPtEMfHiAXB5E5jC2lfFH8ZIOVLNhEHju28JtYwfI
LG Flash Tool: https://mega.nz/#!BB8UgKCT!YAdGWfYGXGLiV5arZzeSGGivtLlW-BuiKlv_ci2Xp0Y
MS34510d kdz file: https://mega.nz/#!VNtDCb6C!wotJiiw1CfVNTlpxG3XRnsgiLNtUmzB6zj3tkraNB9s
Well this worked for my LG MS395 that was stuck in booting into TWRP. Only thing I did different was flashed the ms395 KDZ file and followed your instructions and seems to be good now. Noobified pointed me here after giving me the info for the KDZ stuff. Thanks to all !!!
I stuck my lg in Metro logo ise this method and still the same if the process ends 100 % till the translator starts but stays in the metro logo Spanish aid ablo I use if I do not quite an apology
Hello I need to flashing my lg leon metro ms345 with firmware ms34510e to see if I can unlock, which firmware I recommend that you install and appreciate them to give me the link
As far as I know MS34510E can not be rooted. There's a link at the start of this thread for D
then right now it is impossible .. reflashing the phone or with another version of the firmware?
you speak Spanish, because my English is very bad
I have done this a lot of times with Samsung Galaxy S3's and 4's, but this was a first for me. I bricked my budget LG Leon from Metro PCS while trying to change KingUser to SuperSU. Without you, I would have been lost on this. LG phones are not at all like anything I have done with Samsungs. Your guide and download links worked like a charm. I tried to update my phone from day one, stock, not rooted, to the D firmware and it would not work. Using this emergency recovery worked when the phone's stock firmware and "upgrade" would not. Cheers to you buddy!!!!
Hi everyone I recently messed up lg Leon the imei was null and I was on here looking for a fix.
I found a file made to repair the same problem for a one plus one called efs backup and restore one plus one the thing is that phones mmcblk0's partitions are 10 and 12 while the Leon's is 15 and 16
Just backup the partitions by clicking backup and then open the restore file with a hex editor and where the dd commands are chang e the 10 to 15 and the 12 to 16 and run it and reboot
Hello tnx for tutorial i have bricked my lg leon h324t agter try to downgrade from 10c to 10b but the operation stop at 30% And the phone won't start on and cant entre to download mode any help please and thanks
used this method to return to stock from cm12.1 as i had not made a backup, it finishes 100% but gets stuck on white metro pcs screen during boot. please help. NVM, performed hard reset from external buttons cleared all the data and reset booted right up
I have a MetroPCS LGMS345 running lollipop 5.1.1 and found this thread looking for kdz file for it. It is not bootlooping, just is not quite right. Not going to go into all of it, just some blackmarket apps got installed by someone and its probably malfunctioning due to malware. Will this be ok to flash back to stock? Have the drivers, flash utility and the firmware already in place and computer recognizes phone, just wanted to verify before continuing! Thanks for this post!
Zach
