kamots, eu1, for what its worth:
Here's a post from bftb0 over at XDA discussing Amon_RA and trackball issues: xda-developers - View Single Post - [FYI]Brick your phone with out Bricking your phone hmm !
Here's the text: "Amon_RA runs adbd by default, so you can push/pull files to the SD card no matter what OS (even none) is loaded, and the trackball isn't needed for that.
You can also run nandroid-mobile.sh with Amon_RA booted from the command line (from an adb shell) to either backup or restore prior backups. This does not require the use of the trackball; nor does it have any dependency on "USB drivers".
I think that many other entries in the Amon_RA recovery are implemented as scripts, so probably many things you think you can't do (because of a broken trackball) are indeed possible using an adb shell.
It is possible that your trackball assembly got so bolluxed up that it was also responsible for the loss of USB connectivity; in that case none of this matters.
Bottom line, though - even though it won't fix a trackball problem, is that if you have either the 1.49.2000 S-OFF bootloader running on the phone, or Amon_RA, you can "unbrick" from the state you described.
If USB is gone because of a mechanical/electrical issue, things are a bit more grim than that.
bftb0"
I don't know if the above is applicable and/or will take care of this or be helpful with the issues mentioned.
Also, there's a reference in a g1/Dream version of Amon_RA's reciovery to using the CALL-ANSWER key in Amon_RA to select in case you can't do a trackball press (but I don't know if this is supported in the Eris version). This is discussed in this thread: NEW ! Amon RA Recovery v1.6.2 for the g1/dream(12/13) [Archive] - Android Forums
I've also read that plugging-in your USB cable and gently jiggling it might make you be able to select / move from item-to-item in Amon_RA's recovery menu (i.e., because of the proximity of the USB port to the trackball).
Good luck!
bftb0"
Good luck!
