Unlocked bootload and CM10
I just need to reinstall everything. I think everytime i try to downgrade it says it works but boots back up to ics. Do you need to unroot completely before? Thats probably why it wouldn't push...
Did you try factory resetting?
I do the GB download, i probably need to factory reset. I prolly shouldn't stay up late doing this stuff, cuz its always something easy i miss.
If you're using the right firmware, I have no idea... Are you flashing through the KDZ/unbrick method or the LG tools method?
I'll take any ICS kernels that you can hand to me. GB kernels will not work as far as I know unless they were built on the linux 3.0+ kernel.
Here is EGwolfs kernel based off the LG Lucid stock. He got it to compile on 4.4.0 but not 4.4.7 I think it was.
This is a Linux 3.0 kernel. I'm gonna try and get my environment up and running tonight so I can compile a ICS Rom for our connects.
Is your kernel on github up to date?
Edit: forgot to add link xD
https://github.com/Eagerestwolf/kernel_device_lge_connect
thanks for the help everyone!
it turns out that when your working with a laptop that is less powerful than your phone and no patience, you dont figure out to let it sit and install until you forget it was running in the first place for an hour....
ill be rooting and installing cwm and testing out these kernals tonight tho!
Just to be sure, do i need to flash the beta rom and kernal before the cm10 rom and kernal?
No. The latest one posted is the Rom itself. Try it! :3
http://androidfiles.massivefilehost.com/lucid/lucid_cm10_kernel_5a.zip
This is built from the connect source code. Let me know how this works or if it even boots.
it does not boot.
this probably means nothing, but I tried to build using the iproj source you mentioned. I couldn't get it to boot, but while looking through the configuration, under board settings the display selected was some sort of HD display driver, there was another option some sharp wvga screen was available.
then under another section (something about graphics drivers i think), the lcd driver had none selected as the option which may explain lge.lcd=null. then again I dont understand building kernels very well so this could be completly useless
it does not boot.
What config did you try using? The Spectrums is spectrum_defconfig , not the i_vzw_defconfig.
i tried using the one i pulled from the ICS version for the lucid, from what I could see it looked like it was erroring out when compiling stuff for the i_vzw_board_panel.c and other various i_vzw_board_XXX.c
Which basically means EGwolfs Kernel was unfinished. Figures. We can't pull drivers from a 2.3 Linux kernel can we? That's my only other guess....after that I'm thinking pulling the driver source from the HTC to.see.if that works
I don't understand why we can't, but i went back to ics to snoop around the files a bit to see what i can find out, if anything.
You can't use the lucid config file because the source I have doesn't support the LCD panel you have. Merging in the drivers does not seem to work either as it will compile, but not boot. And correct, you can't mix and match kernel versions.
Im prolly way out of my league when it comes to kernal compiling. Haha
Not really. I went from only basic linux knowledge, to android compiling over the course of a year of digging and reading. It does get easier once you get your first work space set up. After that, it's just a matter of being able to read error logs and figuring out how to fix them.
the display driver the lucid requires doesn't exist in the iproj source. but that driver doesnt work when compiling it with the iproj source.
Response I got from LG tonight. Total load of hogwash.
[FONT=&quot]We are very sorry for the late response because of korea national holidays.[/FONT]
[FONT=&quot]Thank you for your interest about our mobile phone. [/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]“We received your request on LG Open Source Code Distribution site(http://opensource.lge.com). [/FONT]
[FONT=&quot]This site is just for providing source codes of FOSS(Free and Open Source Software) we have used in our product.[/FONT][FONT=&quot]”[/FONT]
[FONT=&quot]Maybe your phone bootloader is locked.[/FONT]
[FONT=&quot]As we know, Verison doesn’t allow to unlock the boot loader.[/FONT]
[FONT=&quot]We hope this information will help you. [/FONT]
[FONT=&quot]Thank you.[/FONT]
[FONT=&quot]Sincerely yours,[/FONT]
[FONT=&quot]LGE MC Company Open Source Code Distribution Center[/FONT]
[FONT=&quot]
Not really. There second e-mail was asking for my error log. I responded yet again that there is no error in the compile. The zImage will not boot. I've asked again for info on what GCC they are using, but I doubt I'll get an answer from them.
