theRealist
I need to go totally back to stock so I can take my EVO in to get a new one due to multiple mechanical issues (can't get beyond 10 hours of battery life even in Airplane mode, my USB port is damaged and my loud speaker is blown out). The issue I'm dealing with currently is a problem in the unrooting process, but here's all the info I can provide for my phone first:
v2.3.5
Baseband Version 2.15.00.0808
Kernel 2.6.35.10-g94d0005
htc-kernel@and18-2#1
Build 4.67.651.3 CL239674 release-keys
Software 4.67.651.3 (stock rooted ROM)
PRI 2.15_003
PRL 60690
Supersonic EVT2-3 SHIP S-ON
HBOOT-6.17.0001
MICROP-041f
RA-supersonic-v4.3-smelkusMOD (team dirt)
I've partially made it through the unrooting process and I got as far as flashing the radio and HBOOT. Here's where the problem is, I'm stuck there because I have a new computer due to my old one biting the dust. My old computer had most of my first nandroid backups on it (moved them from my SD card to save space) to include my ORIGINAL backup before I rooted so I totally screwed myself there... what options do I have because I obviously need a stock Recovery and ROM so I can do a factory reset. Thanks guys! You are always there to save the day!
EDIT: I already tried the RUU method and it did not work. It gave me some kind of error. I tried following the steps to fix it but did not work.
v2.3.5
PRI 2.15_003
PRL 60690
HBOOT-6.17.0001
MICROP-041f
