Duo Maxx3
Bought an Evo 4G online. It came rooted already(still running 2.1) recently the usb port on the phone stop working. Took it to Sprint said it needed to be replaced blah blah so i needed to unroot.
downloaded the recomended files for the unroot section in the thread rooting for dummies. got past the S on part with no problems, then I got to the last part flashing the PC36IMG.zip from the sd card and it said the update was aborted(bad) below I listed excatly what my phone is telling me on the white screen and Recovery Screen
[WHITE SCREEN]
SUPERSONIC EVT2 SHIP S-ON
HBOOT-0.79.0000
MICROP-041f
TOUCH PANEL- ATMEL224_16ah
RADIO-1.39.00.04.26
Apr 14 2010,15:41:34
HBOOT
BLAH BLAH UP DOWN
FASTBOOT
RECOVERY
CLEAR STORAGE
SIMLOCK
HBOOT USB
[RECOVERY SCREEN]
Build: not set
Install : pc36img.zip ?
Press Power to confirm.
any other key to abort.
Install from sdcard...
Finding update package...
Opening update package...
E:Can't open /sdcard/pc36img.zip
(bad)
Installation aborted.
I need help. I dont know what I did wrong. My phone boots and works fine just can't unroot it. it said PC36IMG.zip was for 95 and below.
I have a limited battery life and the replacement will be here tomorrow. The only difference from the instructions and me was I put my sdcard in my computer and transferd the files that way due to the usb port in my phone not working at all.
Please help ASAP.
[WHITE SCREEN]
HBOOT-0.79.0000
MICROP-041f
RADIO-1.39.00.04.26
HBOOT
BLAH BLAH UP DOWN
FASTBOOT
RECOVERY
CLEAR STORAGE
SIMLOCK
HBOOT USB
[RECOVERY SCREEN]
Build: not set
(bad)
Please help ASAP.
. when it loads from the white screen it says
