Root Unrooting Need help
Lortab
Yo man its lortab hit me up on aim im home from work and have a sd card reader and got the pc img file on there but the bootloader wont fire recovery it still just ends up rebooting the phone
next we need to get a stock rom and stock recovery
7.download this file:PC36IMG_SuperSonic_GB_Sprint_WWE_4.53.651.1_Radio_ 2.15.00.0808_NV_2.15_release_209995_signed.zip
8.rename the file to PC36IMG. again make sure that you do not add a zip as windows hides extensions.
9.connect your phone via usb to the pc and transfer the file over to the root of the sd card. also delete the previous PC36IMG file. make sure that you do not get the two files mixed up as they will be named the same.
10.power off then press and hold power+vol down.
11.hboot should see the file and will ask you to update, select yes.
12.verify that you have s-on by going to the hboot screen.
if you have s-on then congrats you are now unrooted!
you can also use this ruu:[ROM]RUU_SuperSonic_GB_Sprint_WWE_4.53.651.1_Radio_2.15 .00.0808_NV_2.15_releaseto get you the latest ota stock rom and stock recovery. just connect the phone via usb and run the exe file on your computer
Ok So I followed everything
and have s-on but i need a stock rom and recovery
The first link provided for donwload does not exist any longer, and the second link gives me an error message when i run it: Its not a valid Win32 application.
Help will be appreciated and thanked!!!
btw is this an exe or is it one i rename onto the sd?
i believe its the one for the card. I stole it from Granite who posted it in another thread.
No haven't seen cynic today. but I haven't really been on today either.
Just like the title states i need a stock rom+recovery .zip file.
The one provided in the how to guide does not exist anymore to download
I believe it does, just a little confusing to get it off of the file sharing site linked.
Halfway down the page is a free slower download area. Click on that green download tab, type in the code, and wait for 20 seconds or whatever time stated. Click on the slower download link and it will prompt you where to save.
This should be the correct file, I've used it in the past. :confused:
ok so in h boot it loads the file and then it doesnt even asks me if i want to update it or anything
wtf?
wtf?
Is it named exactly PC36IMG?
Make sure when you put it on the SD card it isn't named PC36IMG.zip.zip
Windows hides extensions, so it should look like PC36IMG on windows.
can someone please aim me and help me im trying to get back to just stock and cant seem to ****ing do and im getting very frustrated.
obviously my sd card reads in h boot but wont read in recovery or an actual rom.
The other issue is here is my stats i nguess for hboot screen something is wrong seriously . I have tried flashing stock roms and what not from h boot and it doesnt work it just checks the PC36img.zip it never asks me to update ot nanything
Supersonic EVT3 Ship S-on
H-Boot-6.17.0001
Microp-041f
Touch panel Atmel224_16ab
Radio-2.15.00.0808
Mar 8 2011 17:02:15
Please some help me fix my phone if i can just go back to normal ill be happy and never mess with it again.
I have aim and skype please help im about to cry this is soo bad
lol:(
i will pay someone if they get on aim and guide me through this to fix my phone I HAVE to fix it or ill just trash it i guess
Also how did i end up here:
H-Boot-6.17.0001
Microp-041f
Radio-2.15.00.0808
Mar 8 2011 17:02:15
That hboot is way off isnt it?
H-Boot-6.17.0001
Microp-041f
Radio-2.15.00.0808
Mar 8 2011 17:02:15
that is ok. next question is can you get into the sd card via usb cable?
i went and bought one of those sd card readers thats the only way i can put things on the sd card. Can you find a way to instant message me refreshing this forum on here will take forever
