Root unrooting?
deno73
Member
Is there any way to unroot other than sbf? The reason I ask is I used visionary to root my x and if I go back to that restore point and update my phone im afraid that root will not be possible with z4 or can I use the z4 app I've downloaded to unroot visionary....I thought there has to be an easy way to get rid of su. It seems to me there is were people have ran into problems....can I use root manager to to delete or my computer to get rid of that file??? Thanks
this should answer your questions
http://androidforums.com/droid-x-all-things-root/237835-help-how-remove-superuser-permission.html
O.k. so let me get this straight. Even though im already rooted I should be able to download z4 run app let it REROOT my phone. Open app again and use to unroot my phone. From there I can dowload the new update (that's been bugging me to install every 6 hours) then use z4 to root again? Tried to sbf my phone last nite and that isn't working out. For some reason process fails...may ned new drivers, not sure. This sound sound correct to uguys...thanks
