acidbath5546
Hey all, Team Black Hat have released a series of update.zip
TBH Patches: 2.3.340-System, Baseband, 2.3.340-Kernel, Bootloader
This is a series of files that will help you update different parts of your phone. These files have all been tested on Consumer phones and have worked successfully, but as with all things hacking, you are responsible for your own phone and behavior.
Install instructions for each of the files below.
1) Download
2) Restart phone with bootstap recovery
3) Select install update.zip and then select the zip you downloaded
4) Resart the phone
*** When performing the baseband update you will need to reactive using *228 ***
_____________________________________________
MBM 30.04 Updater (also known as the bootloader)
This file can be used to update your phones bootloader from any version to the current 30.04 version. Although the current files 2.3.340 and 2.3.320 both worth with 30.03 and 30.04 this will provide you with the most current MBM.
Download file
2.3.340 Kernel Updater (2.6.32.9-g55626e1)
While the 2.3.320 kernel released by us will work with either the 2.3.320 or the 2.3.340 build, If you desire to have the most current build then download and install this file.
Download file
BP_C_1.09.07P Baseband Updater (also known as your radio file)
Some people have found it difficult to move from the 1.09.06P baseband or have refused official Verizon updates. This file will upgrade your phones radio file to the newest 1.09.07P Baseband.
Download file
2.3.340 System Updater <This file functions the same as the system only SBF file>
This file will update your phone to 2.3.340, you may want to wipe your data partition before proceeding as it can lead to a bootloop. With this file and the others above, you can completely upgrade your phone from .320 to .340 with no need for a computer.
Download file
I'm on Fission 2.2.2. Can I install these, wiping data, and be on official? And then reroot and instal Fission 2.3?
UPDATE:
I installed them all, wiped data/cache, and did a factory reset then installed Fission 2.3.1 all in one reboot.
Don't.
I got stuck at bootloader. I SBFed, updated, rooted with z4, installed 2.3.1, then installed the Gingerbread theme. Worked like a charm.
Same thing here. You can't even go from .315 to .340, you have to first SBF the .320 full version, then the .340 System only until the full.340 SBF is out... Lame but worth it. Apex 1.3 rox!
I have went from 2.3.15 to .340 no problem.
I believe this is the suggested way since you will not get the updated kernel otherwise. If you move from .15 to .320 you will be stuck with the .340 kernel. Even if you SBF the .340 SBF, it is only a SYSTEM ONLY SBF. Which sucks, yet I'm still grateful for.
I was running ApeX - and all I did was load my CLEAN nandroid of 2.3.15 and pushed the OTA through the settings. I lost root so I'm trying to reroot it again. (Isn't everyone doing the Z4 root method now?) I'm trying to find that because it's not in the market, and if that doesn't work I'll do the D2 method.
Will any of this work on the original 2.3.9 leak?
I updated to 2.3.40 with the system SBF in the TBH app. My kernel version starts with 2.6.32.9, but the rest after the "-" is different from the kernel version in this post. Are they the same kernels? Do I need to update?
