MANJUNATH A U
Will you tell me the steps for android 4.0 ice please...............
Cheers
I tried to repartition and reinstall but if kept failing at the same point
I'll await Beta 3 and try again - Maybe the phone has had enough of being changed for a while - on the upside I'm getting great experience in using this
Cheers
Overall impresion is that things work much smoother.
Still I have noticed that:
1) cammera does not work. When I try to run it, I get a message: unfortunatly, camera has stopped. (should I use the previous fix?)
2) wifi works.
3) There is no application for fm-radio (should I download it on the market?)
4) the bluetooth wifi headset does not work.
5) market works.
Thanks for the good work
Tzachi
how do you wipe and install for 2.3.3?
Hi there, I'm currently using Android 2.3.7 Gingerbread SwiftDroid v2 ASIS, I was wondering whether or not it would be recommended to upgrade to this new IceCream Version, I know that there may be a few glitches within it, but would it be a good idea to upgrade to it?
give a heads up when cam is fixed and it becomes a daily ROM so i can download it and have fun...xD
You need to resize the system partition to 200 MB. Download the SwiftBootloaderBuilder. You find some help on xda.
Its recommended 220MB system partition now, the fixes put in beta 3 have put it over 200MB and 200MB causes instability.
when is it going to be fully completed with every thing working? pls anyone
mike he said
I got may phone out of case, connected to service LCD and controlling over screencast, so far beta 4 will be there ...
dudeman i stuck on LG logo what will i do ?
What was the last step you did?
man my phone came from 2.3.7 i wipe using cwm and install from sd. am i doing a mess ?
