Root Updated 8/11/12!! [ROM] 5.07.651.1 SS_Ultra v3.9
MBQsniper
Hey everyone! I was given permission to take over this project (Originally made by blaz1nr) and was given permission to make my own OP to make downloads easier. Now what you will see below was the original OP. I will now be updating/changing this as I see fit. Enjoy!! - Kyler (Creator of the Simplicity and "Slimplicity" ROM)
______________________________________________________________________________
Info:
This will be a continuation of the FirePower Roms. New Roms have been thoroughly checked and completely reworked. Faster, Better, Slimmer, and more reliable. Both Roms include faster scrolling speed, faster app response and withdraw. Much faster overall experience. Lots of bloat removed that was left in.
Some Major work done all around for a noticeable improvement. All Roms may be used as a base by anyone, feel free to dig in. Make sure you {link} back here to make sure I get proper credit.
ROMs:
- SS_Ultra-------Sense 1.0---------
-NS_Ultra v2 -------No Sense[Sense components [completely] removed. Anything you need that's sense type can be downloaded from the Market. when setting up NS keep clicking next,when phone boots enable go keyboard,search key or text box will bring up go keyboard setup. then set up market,email ect. It might be a small pain but well worth it
How to install:
1.Download to Sd
2.(WIPE) everything (3x) recommended.
3.Flash rom
4.Flash Dta2sd (Optional)
5.Reboot and Enjoy.
[Warning:eek:nce you have downloaded this Rom to your device,XDA or myself are not responsible if you damage,brick or otherwise destroy your phone.]
NS_ULTRA HAS BEEN DROPPED AND WILL NOW ONLY FEATURE UPDATES FOR SS_ULTRA
ROM information:
-DeOdexed/Zipaligned
-Bash, Nano & sysro/sysrw
-Busy Box & run-parts
-A2sd enabled
-Init'd / EPSN
-Screenshot enabled
-Stock kernel with Wireless N enabled
-4in1 reboot via custom app
-MIUI Style Battery Bar
-Customizable Quick Settings via custom app
-NEW 3g/4g/Wifi hacks
-Optimized all apk's
-Dalvik bumped to 48m
-Over 300mb on clean install
-Beat's Audio
-Sony Bravia/Xloud
-Rendered GPU
-All New Build.prop/Init'd Tweaks
-Qualcomm Tweaks
-Ram Tweaks
-Sprint Connection Optimizer
-Status Bar Transparencies
-Too much more to really list.
Thanks to Captain_Throwback for the original base.
Issues:
-You tell me.
Download SS_Ultra----> Dev-Host - SS_Ultra.zip - The Ultimate Free File Hosting / File Sharing Service
MD5 Sum: db440e68d9e93e6ab7cb4cc9377afcc7
Download NS_Ultra v2 ----> Dev-Host - NS_Ultra.zip - The Ultimate Free File Hosting / File Sharing Service
MD5 Sum: d997045ab5b2870b0d340ae4ed73a831
(Get more space and speed)
Dta2sd------> Dev-Host - dtapps2sd-2.7.5.3-beta04-signed.zip - The Ultimate Free File Hosting / File Sharing Service
MD5 Sum: 51d3aec8bca833aae85a0a75946ae7e9
Got an HTC inspire? Want a Ultra version? Link to Ultra versions for Inspire 4g--------> http://forum.xda-developers.com/show....php?t=1746038
Changelogs!!
7/13/12:
-Added new Beats audio libs
-Added black flip clock (Thanks SupMah)
-compressed the apks
-Added a couple of new tweaks for speed
-Reduced the ROM size
-Added inverted MMS (Thanks Jessesse)
-Zipaligned again
-Added in he 5.07 hotspot app (huge thanks to ca1ne)
-Themed the lockscreen (I like transparency in case you didnt know lol)
-Added in the extended quick settings for 5.07 (Thanks ca1ne!!)
-Deleted a couple apps I don't think are/were necessary
-Added some custom stuff throughout the ROM
-ROM size: 174.17MB
7/14/12:
-Fixed HTC_IME.apk Force Closing (Huge thanks to blaz1nr)
-Fixed Google Search force closing (Huge thanks to blaz1nr)
-Optimized the apps
-ROM size: 175.91MB
7/15/12: (Minor update, bug fixes)
-Added new tweaks!!! :) the system should be even faster (Thanks blaz1nr)
-Added Uber music and android gingerbread music player
-Added the Telenav GPS fix and fixed HTCbookmarkwidget (Thanks again blaz1nr)
-Minor tweaks done by me to improve performance :)
-ROM size: 186.69MB
7/16/12 (another minor update)
-Deleted a few problematic apps
-Added new RAM tweaks (Thanks ScottyP)
-Added in Titanium backup,
-Added in an app to download inverted apps (thanks rujelus22)
-Added in A2SDGUI
-A couple other things I forgot..
-ROM size: 184.69MB
7/18/12 (test version)
-Added in the sniper script, when your phone boots, let it sit for 10 minutes, and then restart your phone and when it boots, let it sit for another 5 minutes, it is not an actual script, just an all-in-one init.d folder with custom memory tweaks by blaz1nr
-Removed some apps that caused problems
-Should fix any further problems with sync, or force closes
-NEW!! Added ICS MMS, an ICS styled messaging app!!
-Optimized all apks
-More stuff I am forgetting, please report bugs as this is a test run only, nothing is final
-ROM size: 191.80MB
7/19/12:
-Removed Telenav
-Added in ca1nes advanced power menu
-Added in HtcProfileWidget
-Added in hacked hotspot
-Removed some apps
-Zipaligned all apks again
-Added Terminal Emulator and Adfree, an app that prevents ads!!
-Added Imgur
-Added in Flipboard (A neat app!!)
-Added in some more wallpapers
-Added Pandora, spareparts, and XDA too
-Compressed apps a little to save space
-Fixed some problems
-ROM size: 192.54MB
7/20/12: (Skipped to 3.0 because this is such a major update)
-Added in Vipermod script (In case you want to raise or lower voltages, to do that.. go to terminal emulator, type is 'su' then 'vipermod' and you're there.)
-Added in new Beats style logo to replace headphones logo (Thanks PHE-NOM)
-Added in Sense 4 styled clock (widget)
-Added in newer version of DTA2SD
-Replaced ICS MMS with stock MMS (Due to so many requests)
-Added Adfree and A2SD GUI
-Added NoFrills CPU controller
-Added in a few more apps
-Baked in Underworld kernel v8 SBC with HAVS (thanks ca1ne for your awesome kernel)
-Optimized and zipaligned apks again
-Changed default wallpaper to the black one instead
-Deleted the other music app and am using Ubermusic and the inverted Google Play Music app instead :)
-Added in MetaMorph
-ROM size: 188.49MB
7/21/12:
-Removed ubermusic
-Added a new icon (Beats icon with a mic when you plug in headphones with a mic) (Thanks PHE-NOM)
7/22/12:
-Removed Flipboard and Imgur
-Added JellyBean wallpaper app (thanks dfuse06)
-Zipaligned
-Fixed Bluetooth issues!!!!!! (Thanks for the help blaz1nr)
-Removed SMSpopup
-Added Team D.I.R.T wallpaper app (Thanks Mazda/Team D.I.R.T)
-ROM size: 188.47MB
7/29/12:
-Removed Play Store and brought in a newer one
-Raised DalvikVM to 64m
-Switched out the EPST
-Cool new pirate bootanimation!!
-Added adfree, KAK, ext4 support, 270 degree rotation, panorama support for the camera, CPU scaling parameters, and much more (Thanks blaz1nr)
-Added a whole bunch of new apps and widgets
-DTA2SD is enabled after only 1 boot!!
-Faster startup time
-Even faster/smoother ROM
-ROM size: 195.52MB
7/30/12:
-Added in a different EPST
-Added in the stock music app and music widget (Thanks blaz1nr)
-ROM size: 197.10MB
8/1/12 (This update is brought to you by blaz1nr)
-Re-added Sony Bravia and xLoud
-Added in some apps/widgets
-Added in Vinmans theme (Thanks dude)
-Added some more tweaks for speed and reliability
-Switched SU with SuperSU
-Fixed the Multiscript problem
-Removed both keyboards so there is only the stock on now
-Removed the problematic apps
-Added Vinmans Gtalk (Thanks dude!)
-ROM size: 198.51MB
8/2/12
-Removed some apps
-Added Vinmans newer theme
-Added Vinmans Gmail and GTalk
-Fixed a couple of bugs regarding apps
-Compressed apps for a smaller ROM size
8/4/12:
-Deleted some apps
-Added a ton of new apps! :)
-Added a working EPST
-ROM size: 198.73MB
8/6/12:
-Added a Youtube app that plays 720p video, looks really good
-Zipaligned the apps
-Updated to latest Beats audio libs
-ROM size: 214.89MB
8/7/12:
-Added newest Beats audio libs (Thanks Rockodev)
-Added some new tweaks to make it super fast (thanks blaz1nr)
-Added some new theming by vinman (thanks dude)
8/7/12 #2:
-Removed a ton of apps/widgets
-Zipaligned apps again
8/9/12:
-Added in a different Sony Bravia/xLoud
-Zipaligned again!!
-A couple more things, but I honestly forgot
8/11/12:
-Removed some apps
-Added in vinmans latest theme stuff (thanks dude)
-Memory tweaks
-Added in a really cool media player!! (Thanks ssuukk)
-ROM size: 186.78MB
Downloads:
SS_ultra v3.9: Dev-Host - SS_Ultra_3.9.zip - The Ultimate Free File Hosting / File Sharing Service
MD5 Sum: f55734a65f6df459d0672d23e9c8bff0
All ROM versions (Since I took over, not prior to that): Dev-Host - The Ultimate Free File Hosting / File Sharing Service
Personal credits: TommyTomatoe for his android utility, death-by-soap for always being willing to lend a hand, ca1ne for his mods and kernel, blaz1nr for his help/mods/Sniper script, rockodev for his audio libs, pacha for bravia/xloud, Mazda for the awesome banner you see in the OP, deadmau5 for good music, caffeine for energy, and many more!! (If I missed someone, please tell me!)
Sniper script beta1 features!!!!
-Zip align on boot
-Dta2sd setup
-Sets read ahead to 1024
-Busy box setup
-Loopy smoothness tweak
-Battery calibration tweak
-Memory tweaks mix from V6 and Smurfed out. Some values changed.
-Thanks goes out to Zeplinrox & Papa Smurf for the script mastery
-Special thanks to ScottyPeterson and Ultimate Ram Script for giving me the idea, to try to piece together an all in one init.d script.
-Remember this is purely experimental, Any and all suggestions will be taken. Report any suggestion to MBQ or myself.
-The setups inside were not created by us, we pieced together the best mix we could come up with, in order to have a single file to run everything. Some things were reworked, but, the original creators have been given the credits.
Thanks for all your support.
A word about donations:
PLEASE note that IF you do donate I will not give you any special treatment, I Don't do this for money! :)
Nice!! this is a sense based rom then? I havent been on a sense rom in a donkeys age, but i might give this one a go after getting my stupid recovery issue fixed finally (despite having to revert to cwm :( )
Yep! It is sense 2.3.3 with the 5.07 OTA update
Very cool.
I just flashed and immediately started getting FCs for the music app which seems to be killing any sounds. And I can't get my google account to sync at all. Google voice works fine.
Very cool.
either try and wipe dalvik cache and cache and see if that works or try and wipe dalvik cache and cache and re-flash the rom.
what recovery do you have?
New update!! Go get it!! :)
Thanks to those helping each other out in this thread, I spend most of my time on XDA but visit here as often as possible to help out. Anyway, enjoy!! - Kyler, aka MBQsniper
