dmcjr22
Android Expert
Lately ive been seeng posts about newbies lost and not understanding terminology we use. Which is ok we've all been there i know took me sec to figure things out. So maybe the following breakdown can help clear a few things
In order to root your phone your gonna wanna begin by installing clockworkmod(cwm) which can be found here http://androidforums.com/transform-ultra-all-things-root/593840-cwm-new-clockworkmod-fixed-no-2min-reboot.htmlfollow instructions and hit mavs thanks button this will not give you root but will give ability to flash roms that will give you root but before u do so read the following to get understanding of what everything means
Quick Terminology
Flash just means to install
Download mode this is used for odin its done by when phone is off u hold vol down and camera and power at same time
Recovery Mode this is used to get into cwm by having phone off holding volume down and power button when samsung appears let go of power button
Odin for computer to push files to phone in our case to install clockworkmod you need to put phone in download mode
Clockworkmod(cwm)is software for phone to backup,restore roms flash themes,kernels amongst other things to get to it you need to put phone in recovery mode
<<<<<<<<<<<<<<<<<<<New Rom Installation Instructions>>>>>>>>>>>>>>>>>
If its first time flashing a rom make a BACKUP its always good to have a backup of your stock rom
<<<<<<<<<<<<<<<<<<<<<<<Backup Instructions>>>>>>>>>>>>>>>>>>>>>>>
1---Put phone into recovery mode(CWM)
2---While in CWM choose backup and restore,then choose backup
3---Let CWM run script, it will tell you when its finished
4---For safety purposes store your backup somewhere safe ie on your pc
<<<<<<<<<<<<<<<<<<<<<<<Installation Instructions>>>>>>>>>>>>>>>>>>>>>>
1---Place Megatron i mean desired rom(zip file) onto sdcard(OCD says create a folder to keep sdcard neat).
2---Put phone into recovery mode.
3---Now that your in recovery mode wipe the following
Dalvik Cache and cache.
4---Now choose install zip from sd, then choose zip
from sdcard, choose rom
5---You let cwm run script it will tell you when instalation is complete when prompted reboot and enjoy!
Note if you are installing rom from either stock rom or changing roms its recommended that in step 3 you also choose wipe data/factory reset, also if rom developer says to
Credit for this new instructions go to xaelith thanks for help writing and pointing out to update installation instructions
MD5 MISMATCH-there are many different reasons why this occurs but two common reasons are either the file is corrupt meaning when was made there was error or because of either you renamed folder or when u transferred it to sdcard clockworkmod\backup folder its actually inside a folder within, cwm has to see the correct folder to restore correctly.Meaning if the file/rom is placed on sdcard like clockworkmod\backup\whatever folder\your rom for example you will likely get md5 mismatch correct way is clockworkmod\backup\your rom
<<<<<<<<<<<<<<<<<<Recommended apps for rooted phones(superuser)>>>>>>>>>>
Root Explorer- this allows you access to your sdcard and the
phones files.
App Manager-this is to obviously manage apps you download but also
for apps built in phone(stock apps)
Terminal Command- this is something similiar to command prompt
for phone dangerous app if you dont know what doing so becareful
when using
The apps i use are esfiles(root explorer) titanium backup(app manager) terminal emulator to give you an example if you dont know what to search for but we all have or own taste
So i hope this clears up any confusion you may be having if i missed anything or messed up please correct me
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<UPDATED>>>>>>>>>>>>>>>>>>>>>>>>>>>>
<<<<<<<<<<<<<<<<<<<<<<<<<USEFUL THREADS>>>>>>>>>>>>>>>>>>>>>>>>>
Brother Thread
Boost Lounge---Boost Transform Ultra Lounge - Android Forums-Slayer72
Troubleshooting---http://androidforums.com/boost-transform-ultra-lounge/637762-help-troubleshooting-corner-transform-ultra.html-Slayer72
GUIDES
Transform Ultra guide---http://androidforums.com/transform-ultra-all-things-root/626784-samsung-transform-ultra-all-in-one-root-mod-guide.html-NGD1
Odin/CWM---http://androidforums.com/transform-ultra-all-things-root/559890-video-how-root-your-2-3-6-phone-using-odin-cwm.html-Loota
Codes---http://androidforums.com/transform-ultra-all-things-root/516800-sprint-boost-codes-transform-ultra.html-chevanlol360
Apk Modding---http://androidforums.com/transform-ultra-all-things-root/631337-diy-how-decompile-apk.html-niteNarmor
Theming---http://androidforums.com/boost-transform-ultra-lounge/635448-guide-all-in-one-theming-guide-under-construction.html-xaelith
Theme Background---http://androidforums.com/transform-ultra-all-things-root/625754-how-change-system-background.html-katracho
Boot Animation---http://androidforums.com/transform-ultra-all-things-root/585623-how-re-enable-custom-boot-animation-in-2-3-6-a.html-katracho
Boot Sounds---http://androidforums.com/transform-ultra-all-things-root/632296-how-change-your-boot-up-sound-hard-way.html-oamilcar
Prl---http://androidforums.com/transform-ultra-all-things-root/632275-diy-how-change-your-prl.html-niteNarmor
Ota---http://androidforums.com/transform-ultra-all-things-root/580724-blocking-ota-updates-sprint.html-cwgraf71
App Removal---http://androidforums.com/transform-ultra-all-things-root/624163-app-removed-list-form-me-reapert-new-info-9-30-2012-a.html-reapert
Disassemble Phone---Samsung Transform Ultra Disassembly & Reassembly - YouTube-powerkane
<<<<<<<<<<<<<<<<<<<<<<<<<<<<THANK YOU>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
chevanlol360 mavrikmeercat Loota Slayer72 NGD1 niteNarmor xaelith reapert oamilcar katracho cwgraf71
THANKS TO ALL OF THE TU DEVELEPORS FOR WELL EVERYTHING ALWAYS HIT THERE THANKS BUTTON ALWAYS NO EXCEPTIONS WITHOUT THEM WE WOULDNT HAVE ROOT
Quick Terminology
phones files.
when using
Brother Thread
GUIDES
