I have flashed a stock rom(one packaged) on samsung galaxy gio gt-s5660, using odin 4.42 and GIO_v1.0.ops file.
the original stock rom does not support arabic language.
Before I flashed the arabic stock rom, I first rooted, changed the standard recovery to cwm recovery , made a backup of the original rom, and flashed a custom rom. I did this because I hoped the custom rom would has arabic. but no. It also was my first time flashing an android phone.
Could I use Odin 4.42 and the ops file, to restor the original stock rom I have bakcupped with cwm?
After flashing the arabic stock rom gps does not work anymore. I have tested it out on an app called maps (from google). It keep saying that gps is searching for signal.
The reason why if because the modem version is not the same. the original stock rom and the first custom rom without arabic language support had the same modem version. Alhtough I have not tested the gps, but I assume it works.
The arabic rom has another modem version. that explains the problem I have.
No my question is: I read a thread here on this forum ( odin and stock rom tutorial: androidforums point com/551-all-things-root/480888-odin-stock-rom-tutorial
there a one packaged and seperate files Rom. Could I use a modem file with the same version as the original stock rom and only flash this file, with odin 4.42 and the ops file.
Where can I find such roms with separate files? I only find one packaged rom.
I still can fix the smartphone if I use odin again, if I decide to give it a try to flash only the modem file. at least I hope?
What are your opinions?
informations about the rom:
original stock rom:
Android versie: 2.3.3
baseband versie: s5660xxkpa
kernelversie: 2.6.35.7-perf-cl561624 root@DELL122 #1
BUILDNUMMER: gingerbread.xxkps
custom rom I tried :
ROM: enhanced236_06.08.2012
android version 2.3.6
baseband version: S5660XXKPA
kernelversion: 2.6.35.7-px-based-kernel dhiika@phiexz #20120607
buildnumber: enchanced236_05.08.2012
arabic rom:
ROM: United Arab Emirates
baseband version: S5660XXKT6
kernelversion: 2.6.35.7-perf-cl1013784 Ddpi@DELL171 #1
buildnumber: gingerbread.jpkt7
original stock rom:
arabic rom:
