Root V6 Supercharger
I was just wondering do I have to run this script every time restart my phone?
Some of the more experienced folk told me that wouldn't be necessary. Before I heard that, I did a few times. The results it showed of what it did to my phone were the same subsequent times. It shows the before and after settings.
Hey to everyone, first time posting in the forums. I am running MiK3d rom with Gm 1.1 kernal and just installed the supercharger script, just had a quick question. I think it installed correct, my only issue is that on the xda forums it says that the script should read, if it installed correctly "Launcher is .... HARD TO KILL!" and just above "NOTE: Current Minfrees = 6, 8, 26, 28, 30, 32 mb" its WORKING!", mines says all of that as far as the minfrees, but it says "launcher is BULLETPROOF! ie. SUPERCHARGED". it kinds means the same thing to me, just figured i'd ask to be sure. thanks...
Try using launcher pro or adw.launcher they both give options to enable or disable "lock home in memory"
and out of memory could most likely be your internal memory? Try delete old/unused .apk files and ringtones and such
and correct me if im wrong ^
