Just a heads up, Android 4.0.4 is being pushed to AOSP today according to twitter world. Can't wait till the ROM devs get this incorporated into their ROMs!
Don't shoot me, I'm knew to all this ROM stuff...so how long does it take to translate into a usable ROM...let's say by AOKP.
So when I was running 4.0.4 stock with the Franco 18.2 kernel, my phone would randomly shut off and would require a battery pull to restart again for no real reason that I can think of. So I'm not sure if it was the kernel not working on my phone, or if it was 4.0.4 itself not working. But now I'm running AOKP b28 with LeanKernel 2.7 on 4.0.3 and no issues yet. Is it possible that 4.0.4 was causing those issues, or is it more likely to be Franco?
The only reason I ask is because I'd be hesitant to run, say AOKP, on 4.0.4 again if it was indeed 4.0.4 causing those problems.
you have to understand that the .4 variant you were running before was not compiled from source code but rather a leak that dropped for a device. Source code should clear up a lot of issues that Roms may have had when trying to use that leaked .4 build. Take B.A.M.F for instance they chose to only use pieces of the .4 leak that came out, if i had to guess one of the reasons would probably be compatibility issues.
Can i just politely remind everyone that new source code will do nothing for the signal issue/reception that the VZW Nexus is plagued with for a lot of users? If you don't have signal problems then this is great news. For those of us that do have them (me) .4 source means very little to me.
i'm seriously becoming frustrated with Android/Google at the moment.
I sympathize. I guess you have ran the exchange for another phone, replacement SIM card, gauntlet?
You make me feel lucky. I got mine on release day and although sometimes the signal bars are low it has not let me down. 4G has even silently moved into my area.
yes i would definitely give it another chance. Custom Roms will only improve with each official release of Source. I can't wait to go back and try Redemption Rom after Lou rebuilds it from the new source. Granted i'll still have the signal reception issue but at least i can smoothly navigate through my phone even better than now.
