[Verizon] [KERNEL][26 JAN] GLaDOS V1.5
WormDoes
Android Expert
Didn't see a thread for this kernel either so I thought I'd make a one. I have been running 1.4 for a few days and the battery life is some of the best I've had. I going to flash 1.5 now and expect the same results.
FWIW, I was running 100/100 on 1.4. I tried flashing 110/100 on 1.5 and got stuck at the splash screen. I don't care about OC, I flashed it because I wanted to run 1.06 instead of stock 1.2ghz. I may try 105/100 if I'm not happy with 100/100
[KERNEL][26 JAN] GLaDOS V1.5 - RootzWiki
Cheers!
I've been wanting to test drive this kernel, but I've been so floored with another one lately. It looks brilliantly done and I love reading the devs posts seems really knowledgeable. In due time, thx for posting it over here at the AF!
Crapppp my phone doesn't like any kernels other than Imos. Whenever I try to call someone the screen just goes black on ANY kernel. Stupid voltages
If on AOKP ROM do you have "power saver" enabled by any chance?
If so turn it off
It's unlikely other kernels voltages as a lot of other kernels don't even under volt aggressively like Imoseyon does.
Then I am very confused. Because I can only make phone calls on stock kernel or IMO kernel. Very confused.
Also Power Saver has never been on.
