[Verizon] [MOD] Battery Booster
If you're going to post results, make sure you mention if you're on the extended battery.
On aokp m6 and ext battery, if I forgot to charge my phone, I'd have about 14% battery after 24 hours. This would be with little use so maybe a call, definitely updating apps, checking email ~ about 20-30 minutes of screen-on time. This would be on wifi when home and 4g when away.
I get better battery with JB roms, like XenonHD.
That said, I'm interested in what you guys get for results. I WILL say this tho, I definitely use my phone more with JB installed. :D
Left my phone on for 6.5 hrs after a battery swap earlier, Used 15% within an hour actually playing with it. Since then 8% loss over the other 5 hrs. Not bad for 2 bar 4g
Can't give a review yet. In a spotty service area, and battery usually gets a killing when it's searching for service.
Well it didn't break anything lol
Well I haven't had a normal workday running this ROM, so I have no base to go off of. I know what my battery drain while idle had been with the last ROM I was on, so I'll see how this compares
I'm pretty impressed. Its not often I get home from work and I have more than 50% battery left. I left my house today at 8am, had 93% left on my battery. Didn't touch my phone till 11:15, and was at 88%. Now mind you i'm UPS driver so i'm always moving and switching towers. Used my phone a few times between 11:15am and 3pm, usually at 3pm I'm at 70% but I was at 78%. Pretty impressive.
I'm on 3G only, using Liquid's Jelly bean ROM.
I don't have a very good connection at my house (barely 2 bars of 3g) so I need WiFi. Plus isn't WiFi supposed to help?
Well yeah but I mean that I have it set in my settings to turn wifi off once the screen is off for awhile. So I have no data connection at all
Not as of yet...I can make a zip file that will restore it if you want. Are you having trouble with it??
OP UPDATED WITH BATTERY BOOSTER REMOVER!!!
and a quick screen shot of my battery life on my last full cycle (100% to 1%) ;)
this is on BAMF with lean kernel, underclocked at 920mhz (with no lag) and with data off unless i need it (its not too hard to turn it off and on with those awesome toggles in BAMF) and with moderate use. (a few calls and texts, watched a little bit of horrible bosses on my lunch break, check android forums and facebook about once an hour).
the stats dont lie peeps ;)
Holy crap dude...what is your setup? Are you over clocked or anything? Do you leave 4g on all the time??
I'm on jelly bean stock, I'm on franco kernel r225, using the app on the balanced power plan thing. I turn off data most of the time when I have Wifi on. At night I turn off Wifi and data, enable silent mode and that's it...
