ryancmatchett
Android Expert
flashed 24 and the new gapps last night...looking good so far!!!
I'll tell myself it's not worth it...but I've flashed every build since 17 so I may just do it for the heck of it
Just a question about this rom. I'm sure this is a dumb question, but what is the mirror 1 mirror 2 and mirror 3?
I want to download the build 24, but don't want to do anything wrong since I haven't used this rom before.
Just curious which one I should download. I'm currently on CNA with franco kernel if that matters
My guess is that Milestone 4 will be the next drop, with the Hide NavBar option perfected.
Ok build 25 first impressions...the text signal works as you would expect if you're in to that sort of thing...it's big, clear, and simple for those geezers in the forum.
Oh I hope not. I don't flash milestones.
Rather than having your signal bars, it displays the dBm number in a nice, large, clear, fontGeezer? Thats me. What is that you speak of? Text signal? The scroller at the top when a message comes in?
Seems to be a Milestone after every 5 or so builds. I won't be flashing M4 either.
Rather than having your signal bars, it displays the dBm number in a nice, large, clear, font![]()
Looks like I am going to have to jump back in from an M-build. Cannot stand it!
I guess a full wipe factory reset is in order eh?
I'm a little rusty,
Or is wipe data / factory reset all I need?
- SDcard external backup.
- Nandroid.
- Boot to recovery, Wipe Dalvik, format /system/
- Wipe data / factory reset.
Is that the only thing? Or can I have the signal bars? I'd be really happy if they would just put 3G, 4G or SOL up there.
Have you seen this MOD?
I'm on M3 - I've considered doing nightlies, but is there an easier way than manually pushing the rom onto your phone each time you want to install an update? It may not seem like much hassle, but to me it's enough of a hassle for me not to switch.
