jackburnt
It's taking some getting used to. It took me a while to figure out how to play an album without Shuffle.What do you all think about the new Google Music app?
Looks slick though.
Did you dirty flash over the previous ROM?
I did the reset and cleared the caches. I was on a different brand of ROM, so I figured I probably should just clear everything. It was a pain downloading all my apps again, but oh well.
It's "pure."Is this ROM pure AOSP? Or are there any tweaks to it?
Is anyone else having issues with Nova Launcher on JB? Whenever I try to drag and drop icons, sometimes it doesn't let me drag them and instead brings up the Edit and Remove menu. Kinda of annoying but tolerable
Yup I've noticed a few glitches with Nova and JB. Nova is still very beta on JB and I went back to the stock launcher because those little quirks bothered me so much
Titanium Backup is your friend...![]()
I know this will sound totally insane, but I actually preferred it that way. It gave me a chance to go through and only load back what I really use. Plus, it gave me a little project for 30 minutes.
I noticed this too, but it seems like it's just a matter of timing. If you wait too long to start trying to move it, that menu pops up. I've only gotten the menu once or twice since I realized I had to try to move it pretty much right away.
lol. Pete has a loyal following. I'm sure, if not by now, someone will have a good battery mod for you. I think the users name is willyjay (who has been making mods for jelly belly) was/is an avid BB user for quite a while. I'd be willing to bet (with some testing of course and some backups before testing) that his mods he has posted would work for BB. I know, it takes some time making backups just to flash a battery mod, but it might be worth your while. If it works, just think how many people you might be able to help who want that mod!
About the only issue I am having is that Google Wallet doesn't appear to want to add funds now.
Edit: False alarm. Rebooted and it worked fine.
I'm flashing BB coming from stock 4.0.4, do I need to reset Google Wallet before I flash to avoid that secure element issue?
I just nandroided and flashed the new LeanKernel 4.1 over the 7/13 BB build in hopes of better battery life so I'll be sure to post back my results.
Where did you get this from?
Over at rootz. Everyone's saying it's working fine, but I haven't noticed any different in life yet really, but kernels take a couple days to break in, at least that's what I believe.
EDIT 1: Just a quick update running LeanKernel. Idle drain is much better running this kernel. It's been 2h 10min since unplugged and while I haven't used the phone much (9mins screen on time), I still have 91% remaining. Much better than yesterday where I would lose 10% in 30mins.
The stock kernel was running ok for me, I was dropping about 6-7% per hour but I also have the clock speed set for 920 max and it doesn't seem any slower at all. I just installed LeanKernel and Ill see how it goes.
